Results 1 to 5 of 5
    Nov 2003
    if it's the head gasket the water should not creep up to the spark plugs. dapat nasa piston area lang sya. unless you have a crack in the head. if so it might be from that
    May 2007
    If water goes to your spark plug you have a bad seal.
    Aug 2003
    bad seal of what? valve seal?
    i'd take this car to Speedyfix but it's unregistered.. and with the water-in-the-plug-wells, it's scary to drive. :-P
    i don't need the aggravation of doing stuff myself.
    Nov 2003
    a defective valve seal or even spark plug oil seals will not result in water. it's either it's from d head gasket na very worn or a crack in the head siguro. the first just check if the water jumps out from the rad. if it does then that's the answer. if the head is cracked though you have to pull it out and have a machine shop do a crack test on it.
Water in Spark Plug Wells
