Results 1 to 10 of 16
- Nov 2003
- 36
September 28th, 2005 05:40 PM #1hello...
advice naman po..
nagoverheat kanina yung makina ko..
then dinala sa talyer...
sabi kailangan daw palitan ang water pump kasi may tagas..
then magpapalit na rin ng radiator hose at gasket...
tapos kailangan daw ng bagong cylinder head kasi may bula daw, parang leak ata dun nung pinalitan before yung valve seal...
ndi ko sure kung dapat bang ayusin yung leak.. which means magpapalit ng ng cylinder head..para maayos ang oeverheating problem?
the quote is 10K for this whole problem..is it reasonable?
please advice..thank you..
- Nov 2003
- 36
September 28th, 2005 05:45 PM #2by the way...Centennial Auto Services Inc. pala yung shop..sa may Makati..
thanks..
September 28th, 2005 06:25 PM #4
A replacement water pump costs 1k more or less from what i know (CMIIW). If you have a damaged water pump, the usual symptom is you lose water WHILE the engine is running.
September 28th, 2005 06:54 PM #5
I suggest that you take it a more reliable talyer for a second or third opinion. Maraming tsikot forum members dito ang may talyer na ok. Sounds like rumaraket yang talyer mo.
September 28th, 2005 06:57 PM #6
1800 yung water pump ko. FYI. GMB yun, "reputable" replacement.
i assume when you say "cylinder head" you mean cylinder head GASKET. 600 ang replacement nun. mahal kung cylinder head talaga :D
- Nov 2003
- 36
September 28th, 2005 07:15 PM #8salamat sa mga advices/comments..
eto yung quote sa akin...
water pump - 1450
cylinder head - 1200 ...ndi ko sure kung head nga talaga...
radiator hose - 550
gasket - 800
labor for the change of pump, installation of hose - 1500
labor for cylinder installation - 2500 ..kasi ibababa daw ang makina
machine shop - 1200..kailangan daw ipamachine shop..
yung mga may talyer na tsikoters...please PM or post na lang..
baka in the future sa inyo na lang ako pagawa...
thanks..
September 28th, 2005 07:23 PM #9
diba sobrang mahal ng cylinder head?
ang alam ko ito yung buong upper part ng engine block eh (the part with the valves and stuff) na nag-wa-warp pag nag-overheat ang engine.
with that pricing, baka nga cylinder head gasket. :P
Toyota is my choice
- Aug 2005
- 2,063
September 29th, 2005 01:35 AM #10ang mahal naman.. kung hindi pwde tawad punta ka iba shop yong reliable magtrabho and may ma save kpa.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
