toyota sell pre-mix coolant (50/50 ratio yata ito). we use 50/50 distilled-water/coolant ratio.
di po ba ang coolant is just to prevent over heating??? tama po ba ko??? taka lang me kong ano talaga gamit ng coolant just for preventing corrosion lang???? thanks po sa reply![]()
Can you mix different brands of coolant but same type or not? Ex caltex mix with prestone. Also if the manual says use dexcool type coolant will it matter if i use a different type say ethyl glycol?
Normally 50/50 ang recommended ratio ng manufacturer but you can
decrease it to 80/20 because tropical climates like Pinas, useless na
ang properties niya to prevent freezing so the anti-boil and rust properties
na lang ang habol natin.
Actually, coolant is recommended even in tropical weather. Tech&tuner did an excellent article on this, also.
Basically, at 50/50, your boiling point is raised higher, so your fluid will have less chance to boil over, at lower ratios, the boiling point of the fluid is lower, and the possibility of having water boil at cavitation points within the engine increases.
While it's possible to run engines on 100% water, a 50/50 mix will give you much better performance.
And like I said a few posts (and a few months) back, there are already systems using 100% coolant (not off-the-shelf stuff, special coolant), and the guy I talked to who uses it for his racing car says it gives much better performance than a mix.
If you can find a REdline water wetter that would be great.
" WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations. "
Tried and tested.
mga sir, walang sumagot sa tanong ko - san po nilalagay ang Engine Coolant? ano ang kaibahan ng engine coolant sa radiator coolant? thanks a lot!
Brod pwedeng magtanong magkano ba ang coolant sa toyota,caltex,prestone etc?salamatOriginally Posted by mcbry
reviving an old thread...sorry for this guys...
san nilalagay ang Engine Coolant? dun ba sa container na nakalagay "coolant only"?
Thanks!
You fill both the radiator and the reservoir (jug) with the correct mix on most vehicles (separate cap for radiator and reservoir). If the coolant reservoir and the radiator have only one cap, that is where you fill.
I use 50/50 so I don't have to worry so much about diluting the mixture during top-ups.
