Results 1 to 6 of 6
    Can you you guys recommend a shop where I can bring in my civic for a 100,000K service?
    Was planning to have it serviced at hondakal sana kaso sobrang mahal daw nun, ano ba usually mga parts na pinapalitan dito aside from oil change,spark plugs,water pumps and timing belt?
    afaik, kailangan din i change yung engine coolant, at fliud (kung at car mo), gear oil and kung kakayanin pa, brake pads. you can try carsavers makati.
    Feb 2003
    sabi sa casa.....
    20,000 km., 60,000 km., 100,000 km., 140,000 km., 180,000 km. Preventive Maintenance Check
    Change Engine Oil and Filter
    Replace Fuel Filter (Carburator)
    Inspect Tie Rod Ends, Steering Gearbox and Boots
    Inspect Suspension Mounting Bolts
    Inspect Exhaust System
    Inspect Brake Lines and Connections
    Inspect Front and Rear Brakes
    Inspect Driveshaft Boots
    Inspect Fuel Tank, Fuel Lines and Connections
    Inspect Belt Tension and Conditions
    Inspect Distributor Cap and Rotor
    Replace Air Cleaner Element
    Clean Spark Plugs (Replace If Necessary)
    Inspect Ignition Timing and Idle Speed
    Inspect Brake Fluid Level
    Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer)
    Inspect Battery Electrolyte Level
    Inspect Compressor Clutch and Joints
    Inspect Condenser Of Dirts and Insects
    Inspect Freon Gas Level (Check Sightglass For Bubbles)
    Inspect Engine Cooling Lines and Connections
    Inspect Steering Pump, Lines and Connections
    Inspect Parking Brake Adjustment
    Inspect Clutch Free Play
    Rotate Tires (Check Conditions, Wear And Pressure)
    3,400++ yung price.
    ang mahal naman niyan!!!!!!!!!!!!!!!!!!!!!!!!!!!
    eh puro inspect pa lang yan dba... change oil, filter and spark plugs lang ang sure jan tapos P3,400 na?
    Sir wrecker thanks for the info, Pero as far as I can remember ang ginastos namin dun sa prev civic ko (ESi 93) nung naka 100,000 eh kulang 14,000 ata. Kaya ngayon yung vti iniisip ko same price din yung magagastos ko sa vti ko pag nag paservice (hu-hu-hu) :confused:
    Feb 2003
    well depende yun sa kung may kelangang palitan e...
    katatapos ko lang ng 65k PM ko last week and it cost me 2007.00 pesos...
    yung mga recommended for replacement sa labas ko binibili at pinapa-install...
    try mong i contact si Migs ng Speedyfix they do PMS. He hangs around sa HCP and AI boards.
100,000 Kms PMS vti
