Can you you guys recommend a shop where I can bring in my civic for a 100,000K service?
Was planning to have it serviced at hondakal sana kaso sobrang mahal daw nun, ano ba usually mga parts na pinapalitan dito aside from oil change,spark plugs,water pumps and timing belt?
afaik, kailangan din i change yung engine coolant, at fliud (kung at car mo), gear oil and kung kakayanin pa, brake pads. you can try carsavers makati.
Change Engine Oil and Filter
Replace Fuel Filter (Carburator)
Inspect Tie Rod Ends, Steering Gearbox and Boots
Inspect Suspension Mounting Bolts
Inspect Exhaust System
Inspect Brake Lines and Connections
Inspect Front and Rear Brakes
Inspect Driveshaft Boots
Inspect Fuel Tank, Fuel Lines and Connections
Inspect Belt Tension and Conditions
Inspect Distributor Cap and Rotor
Replace Air Cleaner Element
Clean Spark Plugs (Replace If Necessary)
Inspect Ignition Timing and Idle Speed
Inspect Brake Fluid Level
Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer)
Inspect Battery Electrolyte Level
Inspect Compressor Clutch and Joints
Inspect Condenser Of Dirts and Insects
Inspect Freon Gas Level (Check Sightglass For Bubbles)
Inspect Engine Cooling Lines and Connections
Inspect Steering Pump, Lines and Connections
Inspect Parking Brake Adjustment
Inspect Clutch Free Play
Rotate Tires (Check Conditions, Wear And Pressure)
Sir wrecker thanks for the info, Pero as far as I can remember ang ginastos namin dun sa prev civic ko (ESi 93) nung naka 100,000 eh kulang 14,000 ata. Kaya ngayon yung vti iniisip ko same price din yung magagastos ko sa vti ko pag nag paservice (hu-hu-hu) :confused:
