Results 1 to 6 of 6
- Sep 2003
- 81
October 7th, 2003 01:16 PM #1Can you you guys recommend a shop where I can bring in my civic for a 100,000K service?
Was planning to have it serviced at hondakal sana kaso sobrang mahal daw nun, ano ba usually mga parts na pinapalitan dito aside from oil change,spark plugs,water pumps and timing belt?
October 7th, 2003 01:19 PM #2
afaik, kailangan din i change yung engine coolant, at fliud (kung at car mo), gear oil and kung kakayanin pa, brake pads. you can try carsavers makati.
October 8th, 2003 06:29 PM #3
sabi sa casa.....
20,000 km., 60,000 km., 100,000 km., 140,000 km., 180,000 km. Preventive Maintenance Check
Change Engine Oil and Filter
Replace Fuel Filter (Carburator)
Inspect Tie Rod Ends, Steering Gearbox and Boots
Inspect Suspension Mounting Bolts
Inspect Exhaust System
Inspect Brake Lines and Connections
Inspect Front and Rear Brakes
Inspect Driveshaft Boots
Inspect Fuel Tank, Fuel Lines and Connections
Inspect Belt Tension and Conditions
Inspect Distributor Cap and Rotor
Replace Air Cleaner Element
Clean Spark Plugs (Replace If Necessary)
Inspect Ignition Timing and Idle Speed
Inspect Brake Fluid Level
Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer)
Inspect Battery Electrolyte Level
Inspect Compressor Clutch and Joints
Inspect Condenser Of Dirts and Insects
Inspect Freon Gas Level (Check Sightglass For Bubbles)
Inspect Engine Cooling Lines and Connections
Inspect Steering Pump, Lines and Connections
Inspect Parking Brake Adjustment
Inspect Clutch Free Play
Rotate Tires (Check Conditions, Wear And Pressure)
3,400++ yung price.
October 8th, 2003 06:41 PM #4
ang mahal naman niyan!!!!!!!!!!!!!!!!!!!!!!!!!!!
eh puro inspect pa lang yan dba... change oil, filter and spark plugs lang ang sure jan tapos P3,400 na?
- Sep 2003
- 81
October 9th, 2003 11:10 AM #5Sir wrecker thanks for the info, Pero as far as I can remember ang ginastos namin dun sa prev civic ko (ESi 93) nung naka 100,000 eh kulang 14,000 ata. Kaya ngayon yung vti iniisip ko same price din yung magagastos ko sa vti ko pag nag paservice (hu-hu-hu) :confused:
October 9th, 2003 02:54 PM #6
well depende yun sa kung may kelangang palitan e...
katatapos ko lang ng 65k PM ko last week and it cost me 2007.00 pesos...
yung mga recommended for replacement sa labas ko binibili at pinapa-install...
try mong i contact si Migs ng Speedyfix they do PMS. He hangs around sa HCP and AI boards.
