Results 1 to 10 of 49
June 14th, 2006 03:06 PM #1
I've got a very slow leak caused by a tiny shoe tack. Which is advisable to do i this case ? The "tusok" method or the cold patch method (requires dismounting the tire from the wheel) ?
Wouldn't the "tusok" method make the hole larger? The hole is almost like just a pin prick .
June 14th, 2006 04:05 PM #2
may malalagot na steel thread inside your rubber tire kapag "tusok" method which will cause "bukol" naman.
June 14th, 2006 05:10 PM #3
Always use the cold patch method. Pag di pwede cold patch, time to get new tires. Don't ever use the "tusok" or "vulcanize (heated)" method. It will only ruin your tires.
- Jan 2005
- 111
June 14th, 2006 05:28 PM #4Originally Posted by russpogi
June 14th, 2006 07:46 PM #5
based on experience, better ang cold patch. yung tusok, minsan di perfect yung seal, at pag napudpod na ulit yung gulong, lumalabas yung tinusok nilang parang thread material na may adhesive. cold patch nasa loob lang at di na-e-expose sa labas. the internal pressure of the tire also helps in ensuring proper seal. hth ;)
June 15th, 2006 04:25 AM #6
- Jun 2005
- 153
June 15th, 2006 10:14 AM #8
mga sir, may kit ba na nabibilhan nung cold patch? saan po and how much? tia
- Nov 2003
- 71
June 15th, 2006 12:41 PM #9Tusok then patch
tusok - seal to prevent corrosion on steel belts then
patch - to prevent air leaking between layers.
- 10,620
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
