Results 1 to 10 of 20
- Oct 2004
- 5
October 5th, 2004 11:15 PM #1newbie po sa tsikot.
mga tsikot gurus, after IHI, ano ang magandang gawin mods sa SOHC na vti-1 d16?
- Aug 2004
- 223
October 6th, 2004 10:19 AM #4
Mahirap mag-FI sa SOHC, durability is not as high as a B-series engine... pero kung low boost lang, ok siguro.
If you have full Intake-Headers-Exhaust mods, there are also camshaft and cam-gear mods available for SOHC motors... but if your Headers are non-orig, I'd suggest bargain-hunting for original parts at Banaue first, as original headers would be good for a couple more hp over fabricated ones... that is, unless you have mandrel-bent headers already... :D
October 6th, 2004 04:15 PM #6
tama si chieffy, actually dapat unahin ang braking power bago ka magpalakas ng motor
- Oct 2004
- 5
October 7th, 2004 01:10 AM #7sir ghosthunter,
heto po ang ihe mods ko.
1.I= knn cone filter.
2. H=421 dc headers with thermal wrap
3. E= 2.5 exhaust pipe with 5zigen muffler
tnx po...
- Oct 2004
- 5
October 7th, 2004 01:27 AM #8tnx po sa mga nag reply.
naka ebc brakepads na kasi yung front ko...parang ok na yata yun.i want to convert rr dram brks to disc brk kaya lang walang makitang available na surplus.also,planning to change to bigger front rotors after the next stage.
suspension ko nmn at tires ay upgraded na rin.outside sa FI, ano kaya ang next procedure to add power?tnx po ulit...
October 7th, 2004 03:13 PM #9
The 2.5 is too big for your motor... 2.0 or 2.25 would give you better torque and the same amount of usable horsepower.
What rims and tires do you have on? Thought they don't add power, lightweight rims and good tires can cut down acceleration times dramatically. :D
October 7th, 2004 04:51 PM #10
whoa, 2.5??? bet you lost a lot of torque in the low-mid power band.
go to the HCP boards, there are rr disc brakes for sale there as well as sir rotors for the fronts
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
