Results 1 to 8 of 8
    Jul 2006
    experts, paano ba malalamn kung sira na ang VTEC? thanks
    imho, pag sira vtec solenoid mo, di mo mararamdaman ang biglaang acceleration at maririnig yung vtec roar pag lumagpas na sa 4500 rpm.
    Nov 2003
    you should know by driving it. i doubt it is broken though unless a sensor is misreading which might cause it to not engage.
    it relies on the speed sensor, vtec solenoid, water temp sensor and oil pressure sensor.
    Nov 2007
    Quote Originally Posted by viper2lt View Post
    this thread partly begs the question:
    ...so 4,500 RPM ang vtec engagement point? Is this true for all civics? (mine is an ek)
    or you can also install a vtec light to determine if and when your vtec kicks in. pwedeng-pwede i-diy. basta basically ang concept niya is whenever the vtec is activated, the light turns on as well sa akin mga 2800 rpm tsaka nag-ki-kick in ang vtec
    check this thread out for more details: http://z3.invisionfree.com/HCP/index...opic=5198&st=0
    Sep 2004
    Quote Originally Posted by owyn View Post
    Depends on the engine. For DOHC engines, 5.5k rpm yata. According to the gurus at HCP, ~3.5k rpm ang for SOHC 1.6 engines. But for my 97 Accord (F22 SOHC VTEC engine), 2.2k rpm lang, VTEC na. (I have a DIY VTEC LED indicator installed, which lights up when VTEC is engaged).
    Nov 2003
    vtec points are different depending on the engine model.
    Hey guys, can you tell me how to find the vtec model? My apologies for my ignorance, but I cant find it eh.
    If ever, 96 model na civic, vti. Thanks!
Vtec
