Results 1 to 7 of 7
    Sep 2006
    mga bro help lang po sa problem ng auto.
    1. my blower ang aircon pero wlang lamig
    2. nawala ang power lock pero ok ang power windows.
    3. lagi naka ilaw handbrake indicator kahit n nakababa na.
    dinala ko sa Honda Pampanga And Honda Manila,, recomendation is to replaced the INDASH FUSE BOX and ECU Or Computer Box..
    mga bro possible ba marepair ang fuse box and ecu,, if possible saan shop pwede dalhin..thanks
    wait for youre reply,,
    I suggest bring it to a reputable mechanic. the ECU suggestion of the casa is BALONEY!
    Quote Originally Posted by papabear_1028 View Post
    1. my blower ang aircon pero wlang lamig - baka wala ng freon, a possible leak in your A/C system, have the A/C system checked/cleaned
    2. nawala ang power lock pero ok ang power windows. - baka yung actuator lang or yung wiring ng actuator
    3. lagi naka ilaw handbrake indicator kahit n nakababa na. - check the brake fluid level
    Sep 2004
    1. my blower ang aircon pero wlang lamig - Pa-check mo sa reputable aircon shop. There are a number of possible reasons, foremost is lack of freon due to leaks (sa hoses, compressor or evaporator
    2. nawala ang power lock pero ok ang power windows.- kung all 4 locks ay di gumagana, it could be the powerlock module itself is defective
    3. lagi naka ilaw handbrake indicator kahit n nakababa na.- whats your ride? The main causes kung bakit umiilaw yung handbrake light are low brake fluid level and thin brake pads. In the accord, pag busted yung brake lamp, pati handbrake light indicator iilaw, aside from the brake lamp indicator
    Im just wondering why the casa would make that kind of diagnosis, medyo unrelated yata sa mga problema mo. You could check the fuses yourself to be sure, sa may kickpanel lang yun ng driver side, yung sinasabi nilang "INDASH." Its not worth repairing an ECU, kokonti magaling gumawa nun, you're better off buying a surplus. Expect to spend at least 7k, depending on the model
    On the handbrake indicator, do check first your brake fluid level, that also works as a warning light when the brake fluid level is low.
    On the A/C, bring it to your suking aircon shop for servicing and a check-up. Could be as simple as it needing cleaning or there's leak or part that needs to be changed (it's hard to pinpoint really without looking at the a/c system).
    Was the car submerged in a flood or anything done to warrant the ECU and fusebox needing replacement??? You can also have a reputable electrical shop do a check to confirm any findings by the CASA on the fusebox (and your power window problems). Try to get a second opinion from other shops that specialize in the a/c and electricals after they do an evaluation.
    Wow, nandiyan na din ba nga tiga-Honda Quezon Avenue?
    Sep 2006
    thanks for the reply.. mga guys.. for the info .. all problem happened for one day.. akala ko fuse lang .. pina cheked ko n sa electrician pero good daw lahat ng fuse.. try ko rin ibang shop pero di nila makuwa ung trouble,, then nagdecide na ko dalhin sa casa,,, im from subic nga pala.. lahat ng shop n pinagdalhan ko dito iisa lang ang sinabi .. dalhin ko na alng daw sa casa:headache:
    saan shop kaya maganda dalhin ung auto? thanks
    la ba A/C shop dyan sa Gapo?
    for your locks and handbrake indicator, kaya ng ordinary talyer yan, basta hanap ka lang ng competent mechanic. Tanong-tanong ka dyan sa area nyo.
help: Indash Fuse Box Assembly For Honda LXI 01
