Results 1 to 7 of 7
- Sep 2006
- 2
November 12th, 2006 05:22 PM #1mga bro help lang po sa problem ng auto.
1. my blower ang aircon pero wlang lamig
2. nawala ang power lock pero ok ang power windows.
3. lagi naka ilaw handbrake indicator kahit n nakababa na.
dinala ko sa Honda Pampanga And Honda Manila,, recomendation is to replaced the INDASH FUSE BOX and ECU Or Computer Box..
mga bro possible ba marepair ang fuse box and ecu,, if possible saan shop pwede dalhin..thanks
wait for youre reply,,
November 12th, 2006 06:03 PM #2
November 13th, 2006 09:25 AM #3
Im just wondering why the casa would make that kind of diagnosis, medyo unrelated yata sa mga problema mo. You could check the fuses yourself to be sure, sa may kickpanel lang yun ng driver side, yung sinasabi nilang "INDASH." Its not worth repairing an ECU, kokonti magaling gumawa nun, you're better off buying a surplus. Expect to spend at least 7k, depending on the model
November 13th, 2006 01:09 PM #4
On the handbrake indicator, do check first your brake fluid level, that also works as a warning light when the brake fluid level is low.
On the A/C, bring it to your suking aircon shop for servicing and a check-up. Could be as simple as it needing cleaning or there's leak or part that needs to be changed (it's hard to pinpoint really without looking at the a/c system).
Was the car submerged in a flood or anything done to warrant the ECU and fusebox needing replacement??? You can also have a reputable electrical shop do a check to confirm any findings by the CASA on the fusebox (and your power window problems). Try to get a second opinion from other shops that specialize in the a/c and electricals after they do an evaluation.
November 13th, 2006 01:11 PM #5dinala ko sa Honda Pampanga And Honda Manila,, recomendation is to replaced the INDASH FUSE BOX and ECU Or Computer Box..
- Sep 2006
- 2
November 13th, 2006 02:07 PM #6thanks for the reply.. mga guys.. for the info .. all problem happened for one day.. akala ko fuse lang .. pina cheked ko n sa electrician pero good daw lahat ng fuse.. try ko rin ibang shop pero di nila makuwa ung trouble,, then nagdecide na ko dalhin sa casa,,, im from subic nga pala.. lahat ng shop n pinagdalhan ko dito iisa lang ang sinabi .. dalhin ko na alng daw sa casa:headache:
saan shop kaya maganda dalhin ung auto? thanks
November 13th, 2006 05:11 PM #7
wala kasi kwenta kahit ano pa tollroad yan eh kung sabay-sabay kayou uuwi. Ang lunas talaga jan...
Traffic!
