Results 11 to 20 of 89
- Dec 2015
- 200
- Aug 2012
- 2,767
February 14th, 2018 03:17 PM #12This is the 12V AC-DC car power supply that I use. Max 10A or 120W. I do not need to turn on the car engine. I just plug this to AC outlet. It is universal voltage so can plug into 100-240V AC.
- Dec 2017
- 118
February 14th, 2018 03:19 PM #13
- Feb 2015
- 174
February 14th, 2018 05:18 PM #14
- Dec 2007
- 727
February 14th, 2018 05:39 PM #15I have this at my car:
VIAIR 300P Portable Compressor Amazon.com: VIAIR 3 P Portable Compressor: Automotive
Though gas station pa din ako magpa-hangin.
Sent from my ASUS_Z012D using Tapatalk
February 14th, 2018 05:45 PM #16
- Dec 2017
- 1,018
February 14th, 2018 06:42 PM #17I simply use this track pump. More than adequate. Kindly note that tire pressure goes down about 1-2psi when it's cold, especially in the morning. It goes back up again when you've driven it for 20-30 minutes as the tyre heats up when used or during the hot day time. So, if your tyre pressure is 30psi and you checked in the morning and it's 28 psi, don't trouble yourself pumping it. It's totally normal. Otherwise, you might over inflate it by 1-2 psi once it gets hot.
- Dec 2017
- 118
February 14th, 2018 07:42 PM #18
- Aug 2012
- 2,767
February 14th, 2018 09:50 PM #19Nothing wrong with using manual tire inflators.
But my wife and dad, and of course myself included, all prefer using the automatic digital tire inflator. Even my 9 y/o daughter had used it. Yes, I already taught her how to check tire pressure and how to add air.
Sent from my ASUS_X00DDA using Tapatalk
- Dec 2007
- 727
February 15th, 2018 12:07 AM #20
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
