Results 1 to 10 of 19
January 29th, 2007 01:45 PM #1
With the traffic we have in metro manila, and even on some provinces, does it beat the purpose of having a turbo timer installed anymore
- Nov 2006
- 263
January 29th, 2007 01:51 PM #2better to have it and not use it than not having one when you need it
question is..how much do you stomp on the gas pedal on a regular basis?
January 29th, 2007 02:08 PM #3
+1. If you can afford one, have one installed. Despite the bad traffic in Metro Manila and in some provinces, you're still going to have the chance to make use of your turbo eventually, not unless you just drive 5 kms thru snail-like traffic at all times and do not plan on taking your ride out of town.
January 29th, 2007 11:43 PM #5
anu use ng turbo timer? I believe it can also be installed even if you dont have turbo, anung use?
January 30th, 2007 12:09 AM #6
turbo timer enables the turbo to cool down safely. since the impeller spins way above 10Krpms, it generates a lot of heat and without proper oil supply/lubrication being generated while the engine is running, the turbo will just break down in no time. the timer's job then is to let the engine running/idling on a preset amount of time after you take your keys off the ignition.
and yes, it can be installed without a turbo. but what for?
January 30th, 2007 12:16 AM #7
Ang turbocharger nag gegenerate ng subrang init, when they operate to produce boost pressure. To counter this, on some cars they are cooled by water (coolant) and by the oil, which is also used for lubrication. Oil and water are pumped through the turbocharger via the mechanical oil and water pumps in the engine. Kaya pag pinatay na yung makina, the flow of oil and water through the turbochargers tigil din. If the turbocharger is extremely hot and you shut off the engine, the oil in the turbocharger may break down (coke) and create deposits in the turbocharger and/or the oil supply and return lines. This buildup of oil restricts the flow of oil through the turbocharger and can eventually cause turbocharger failure. Ang purpose ng turbo-timer is to allow the engine to idle for an amount of time sufficient to allow the turbochargers to cool down to temperatures that will not cause the oil to coke and clog the oil lines and passages. now dahil sa traffic sa atin, where in you are in idle during stop and go traffic, or because of the slowdown ng traffic, nag cocooldown na yung turbo. But in case na you are taking your ride out of town, you can do it manually din by letting your engine idle for a while before shutting it down naman.
January 30th, 2007 05:55 PM #9
i idle it for a while like a minute or two para sure na di masusunog. ang mahal ng Turbo for sure, lalo na yung sa SantaFe, BorgWarner Variable Geo Turbo.
OK din ang turbo timer pero medyo waste of money lang kung AT yung tranny mo. Kasi i can park the car in idle mode, tapos check ng cp, wallet. check stuff. after that, a minute or two have passed already, so pwede na i-off engine.
January 30th, 2007 10:34 PM #10
useful ang timer kung turbo ride mo(particularly the common turbo diesels) at nagmamadali ka (where-in 1-2 minutes could mean life/death or lossing a job.)
other wise, its an additional accessory.
Sa Everest/Ranger parang hindi naman issue yan afaik. Yung EGR pa na nalulusaw ang plastic sa mga...
BYD Philippines
