Results 1 to 10 of 10
Tsikot Member Rank 3
- Nov 2002
- 1,763
September 13th, 2004 09:35 AM #1Hey guys,
Where's the best place I can have my timing belt replaced and around how much will it cost? Its for a 1998 familia. Thanks in advance!
September 13th, 2004 07:19 PM #2
Some shops that came into my mind:
1. Casa
2. Service oriented shops
3. Gasoline station service bays
4. Your own garage with trusted mechanic
A timing belt kit could cost from 4,000-6,000 depending on brand and parts included.
If you opt to buy the items separated instead of timing belt kits, you'll need to change the following items (based from our parts catalogue):
1 idler bearing
1 tensioner bearing
1 timing belt
HTH
- Nov 2003
- 190
September 13th, 2004 08:17 PM #3I'm also interested in having the timing belt replaced on a 98 RAV4. Would the parts come in a timing belt kit? Or would I have to buy them separately?
Also, I would tend to think that the prices of the parts would be more expensive at the dealer's or the casa. Where does one buy genuine Toyota parts? You know, like El Dorado or ATCO for Mitsubishi.
September 13th, 2004 09:16 PM #4
Sorry, based from our ill-revised catalogue, there's only one listing for RAV4 (SXA#1) 3S-FE engine. which includes:
1 tensioner unit
1 timing belt
I think NippoDenso or Nippon Denso Parts in Banawe sells genuine Toyota parts, but not sure if they are priced cheaper than dealers.
September 14th, 2004 12:58 AM #5
eto naman ang timing belt question. along with your tensioner and idler bearing replace your water pump as your ride is already six years old. also the oil seal of the timing gear. that is if you plan to keep your car for a year or more. hth.
- Nov 2003
- 190
September 14th, 2004 08:40 PM #6Thanks for the input, Ungas and afrasay. Shall keep your advice in mind.
But what about coiter's original question: who's a good mechanic for timing belt replacement?
September 14th, 2004 09:21 PM #7
afrasay's cousin is a good mechanic.
- Nov 2002
- 1,763
September 17th, 2004 03:19 PM #10
Had my timing belt replaced at SpeedyFix a couple of months back. Ok naman... I think they moved shop though.
mag bid na ba ako :)
Tsikot.com is for sale!
