Results 1 to 5 of 5
- Feb 2017
- 210
August 3rd, 2019 07:48 AM #1What is this noise? - YouTube
Maririnig ang tunog on the ff scenarios:
1) Cold Engine - Bagong start lang for the day
2) When I open the AC Thermostat and Fan
3) In the middle pag mainit na occasionally maririnig yung whirring sound pag inaapakan ung gas dahan dahan (Automatic)
4)After a couple of seconds mawawala na ung tunog pero sometimes maririnig mo din ang tunog pag lumiliko/cornering
Maaring belt. Pero I also have an issue with the axle boot may tagas/butas ata. posible bang nasa axle boot part na ung tumutunog?
August 3rd, 2019 07:59 AM #2
sa belt yan
madali lang malaman kung belt talaga. cold start and on AC, tumunog diba? lagyan mo tubig, pag tumigil either need linisan ang belt, higpitan or worst palitan.
- 54,216
August 3rd, 2019 09:34 AM #3i think it's a pulley bearing.
some bearings are replace-able.
other bearings are one with the pulley. replace the pulley assembly sila.
spraying with lubricant, may make it disappear. but it will return after some time. replacement is the long-term solution.
good luck.
errr... what car, po?
- Feb 2017
- 210
August 6th, 2019 02:27 AM #4Galing po ako ng Motech, ang sabi ng technician ibalik nalang daw pag hindi na nawala yung tunog
Same ng sinabi nia last year.
Sabi din niya baka daw ung bearing ndi pa naikot pag bagong start.
Anyone po?
August 6th, 2019 05:39 AM #5
Yikes! Definitely a bearing, grabe pano mo napaabot ng ganyan kalala yan.
Anyway, sa mga sinabi mo likely bearing sya ng isa sa mga pulleys holding the belt para sa compressor.
Thanks, I checked them out pero walang Michelin Ang laki ng difference ng price sa Jiga....
Finding the Best Tire for You
