ito sagot ko not particular sa car mo but applicable to almost all. so in other words, generic info ito ok.
all are almost the same. cable lang yan, may adjusting nut sa dulo. look at your gas pedal linkage, trace the cable. check both ends where the cable goes.
there are 2 types:
1. dun sa dulo ng balot ng cable (not on the cable itself, on the cable guide) threaded yun at may 2 nuts. by adjusting the position of these 2 nuts on the threaded section you can adjust the play of your pedals (gas or clutch).
or
2. yun cable mismo is connected to a threaded round bar (or screw if you want to call it that). there are 2 nuts on that screw. adjsutment is same as above.
