Results 1 to 4 of 4
August 6th, 2003 03:24 PM #1
how can i remove the "slack" from my car's throttle cable? masyado kasi malaki ang "play" nya. which on my opinion causes the engine not to respond faster than usual. btw car is a 1997 honda city m/t
August 6th, 2003 04:31 PM #2
ito sagot ko not particular sa car mo but applicable to almost all. so in other words, generic info ito ok.
all are almost the same. cable lang yan, may adjusting nut sa dulo. look at your gas pedal linkage, trace the cable. check both ends where the cable goes.
there are 2 types:
1. dun sa dulo ng balot ng cable (not on the cable itself, on the cable guide) threaded yun at may 2 nuts. by adjusting the position of these 2 nuts on the threaded section you can adjust the play of your pedals (gas or clutch).
or
2. yun cable mismo is connected to a threaded round bar (or screw if you want to call it that). there are 2 nuts on that screw. adjsutment is same as above.
August 6th, 2003 05:30 PM #3
i think yung example no.2 ang throttle cable ko. tried adjusting it pero nangyayari parang ang naadjust yung engine idle speed. nawawala yng play pero ang naging idle speed ay 1200 rpm.
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
