Experience ko pagkatapos mo dumaan sa baha, kinabukasan bleed the brakes and replace the fluid, check the tires, check under carriage, re grease steering components and suspension (if using leaf spring) and run the engine and check if its normally operating. Dito kasi sa Cavite medyo matataas ang baha kaya nung pinapagawa ko pa lang yung jeep namin, i make sure mataas yung ground clearance ng engine ko para di mag stick out yung oil pan ko na mostly lower sa chassis frame. Then all electrical harnesses are tucked up way into the body para malinis tignan at iwas na rin sa dirt at water.Since matic yung jeep ko, i installed the atf cooler sa harap ng radiator which is high enough not to be reach by knee high flood. At mataas kasi ground clearance nung jeep namin. I never like low cars rin kasi, not practical in the roads we have here in the province.
