Results 1 to 20 of 57
Threaded View
    #27
    Thank You sir EssB for the clarification.
    If you didn't take it out from the housing medyo hindi ko maiintindihan.
    Bale po the smaller valve will never close full either partial or fully open. That is why there is no bypass line.
    And the bigger valve will only open when coolant inside the engine needs cooler water from the radiator.
    Tama po ba?
Thermostat removed...help!
