Understanding engine temp.
Usually, thermostat start opening at 80-85C and is fully open at 90-95C.
Your fan switch is on ar 90-95C and off again at 85-89C.
Under normal conditions (outside temps <25 deg. centigrade and good airflow through radiator) the thermometer on the dashboard should be just over 70. If it goes towards 90, the radiator on the thermostat is bad. In exceptional cases the waterpump may be bad. Only extreme circumtances(very high outside temps, long climbs, no airflow to through the radiator) does meter go to 90. Even the coldest days or rainy season, the temps should reach at least 70. if not change the thermostat.
