I just notice while driving on a freeway, SLEX/NLEX at high rev running on 120km/hr.. my engine temp raised to 50%... But on trapik its back to normal even with AC is on... Im talking about Pajero Gen 1....
yon ang di ko alam basta mineral oil lang Sir..can't remember the brand.. sa laguna bearing ko na bili 3weeks ago
hindi kaya kulang sa engine oil??? I charged 5 liters naman?? dapat siguro I have to add another 1/2 liters
Subukan nyo sa synthetic, baka di kaya lubricate ng mineral kasi, maganit mga internal parts nyan.![]()
Parang hindi makahabol ang water pump or may blockage na sa radiator. Ganun kasi nangyari dun sa W126 namin. 1981 model pa kasi. hehehehe.
Ungas
Gusto ko nga fully synthetic kaya lang takot ako since luma na yung engine baka mag leak na yung mga seals?? pero tagal ko ng pinag iisipan kung i synthetic ko ang oil non..
OTEP
Pwede rin danon na flush ko na radiator pero ganon parin kulay ng tubig kulay kalawang pa rin I think it need a radiator overhaul na siguro.. subukan ko muna yon then pag di pa rin palitan ko na sa synthetic oil...(di bale mas mahal basta OK ang makina)
it may be a case nga of some blockage in the radiator or cooling system. i doubnt it will be the oil that is causing the overheating problem. have your radiator repaired nalang and check if the fan/thermostat and switch are all functioning properly![]()
NightRock::: Don't worry your engine has been rebuilt it will run like new. Pinaayos namin ni Larry yan dati and we made sure it will last more than you expected.
Teka, wala ka bang foglights na nakaharang sa harap ng grilles?
Alfred
7 liters ba ang GEN 1 yung kasing na recover ko na old engine oil 5 ltrs lang??? bakit ganon?
Ungas
Ok sige try ko mag synthetic mas palagay kasi ako pag synthetic ang gamit ko.. di naman siguro dahil sa Fog light ang liit lang ng fog light ko..
speedyfix
I'll arranged for radiator cleaning tingnan ko kung may improvement
magpa-lavramon ka muna ng radiator... baka matanggal overheating mo...
happened to me before... had my radiator overhauled. i never thought na madumi sya kasi maganda pa yung tubig after being flushed... nung binuksan, nak ng teteng, daming nakabara na...Originally posted by NightRock
Ungas
OTEP
Add a container of Whiz Radiator stop Leak in your Radiator for sure butas at kulang ang coolant. Available ito sa Ace Hardware at 80 bucks.
is that effective? isn't it better to just have the radiator overhauled and put in good coolant?
