Results 1 to 10 of 17
December 22nd, 2006 02:18 PM #1
mga sir, magandang araw...
patulong naman, after ko mag pa change oil at ATF, nagkaroon ng malakas na vibration sa interior ng kotse pag naka D o R, manibela at dashboard at front seats lakas ng vibration... tapos lumalakas pag naka on ang a/c... pero wala yung vibration pag naka P o N... ano kaya ang problema? accord 94 A/T pala tsikot ko.
sabi ng mekaniko sa shop na nag change oil at ATF, normal daw yun... sabi ko bago magchange oil at ATF walang ganung vibration... normal daw... so umalis ako kasi inisip ko baka mawala... nung dec 19 ako nagpa change oil at ATf... hangang ngayon ganun pa din, kahit buong araw ako nag babyahe ganun pa din kalakas ang vibration. tulong po....
Tsikot Member Rank 4
- Jun 2006
- 2,605
December 22nd, 2006 02:35 PM #21 hindi yan normal. saan ka ba nagpagawa?
2 check your fluid levels, baka kulang.
3 correct type of atf ba ang nilagay?
- Nov 2006
- 299
December 22nd, 2006 03:02 PM #3try to check both oil,smell it,mabango ang engine oil at medyo nasty naman ang atf,and go abck to your mechanic and ask them what is really happen to your car,for sure hindi normal yan,baka baliktad ang pagkalagay nila sa oil,engine oil to tranny and atf to engine,
December 23rd, 2006 12:50 AM #4
OMG! Kung nangyari, delikado yan para sa makina at transmission mo. I hope hindi yan ang nangyari.
In case na hindi naman ganyan ang nangyari, check mo rin yung mga spark plugs mo. Baka isa dyan ay di na gaanong gumagana na or check mo yung cable ng mga spark plugs, baka di gaanong nakalubog maige o maaring sira na rin ang isa sa mga cables.
Bro, give us the name of that shop para naman maging aware din kami at maiwasan namin in case na magpapa engine oil at ATF change kami.
Salamat.
December 23rd, 2006 01:18 AM #5
could be a busted engine support in the middle. basta its near the firewall. if you haven't replaced it yet then it could be the cause of vibration.
December 23rd, 2006 01:34 AM #6
during the change of atf baka may nahugot na small hoses that give vacuum to your idle up switch.
December 23rd, 2006 01:36 AM #7
December 23rd, 2006 07:59 AM #8
i dunno but with my previous accord, it did vibrate like that. at first i thought its an idle problem but it was indeed the hydraulic engine support.
- Nov 2006
- 103
December 23rd, 2006 10:58 AM #9the most probable reason for the vibration is the engine support...you said it yourself that it doesnt vibrate when on P & N...naturally it wont vibrate on those positions because the engine is sitting idle unlike in D or R position wherein the engine swings back and forth
December 23rd, 2006 11:09 AM #10
the thread starter stated that the vib came out after the atf was change. I don't see any connection between the atf and the engine supports, unless the atf contains acid and was accidental spilled on the engine support to ruin it or the mechanics were careless enough to pull the plugs wires from their sockets while the fluid was being change..
