Results 11 to 17 of 17
- Nov 2006
- 103
December 23rd, 2006 11:12 AM #11malay natin sumabay lang yung symptoms dun sa pag change oil nya. mas madali naman pacheck engine support kesa naman gumastos para sa top overhaul
- Nov 2006
- 299
December 23rd, 2006 11:12 AM #12mach,sabi nya nangyari daw pagkatapos lang ng engine oil and atf change,nangyari kasi yan sa customer ko,vibration at any gear,tinanong ko yung may ari if nangyari na to dati,at sabi nya, bago lang daw nya pinalitan ng engine oil ang transmision nya,kaya nung cheneck ko,amoy hamburger na yung trasmission nya.
December 23rd, 2006 11:23 AM #13
i had this problem before and its with the engine support, try checking it, maybe it just gave way.
you can also try checking the fluids of the tranny and level.
December 23rd, 2006 11:24 AM #14
*wrap3pull2:
Are the symptoms felt with the vehicle stopped and you stepping on the brake, or when moving as well? Do you have a tachometer, and if you do, what RPM does it read at idle in D or R with your footbrake activated, and what RPM does it read in P or N?
Answering the above questions may rule out idling problems.
December 24th, 2006 10:42 AM #15
salamat sa mga reply... 5 days na ganun pa din ang situwasyon...
userfriendly... tama naman ATF na nilagay.. castrol Dexron III at 4L nilagay sa 2.0 accord 94 ko.
dennis powell... ok naman smell ng oil at atf, katulad ng binigay mong description... saka huli nilagay yung oil at malaki pinagkaiba ng containers nila kaya malabong nagkamali sila ng lagay.
camarazo... nag check ko na spark plugs at wires... nagpalit din kasi ako ng spark plug oil seal kaya rule out ko na yun.
afrasay... ano sockets/plugd kailangan kong check? sana nga yun ang problema.
mbeige... hindi sya nag vibrate pag umaandar na... once na naka D or R at naka tapak sa brake saka mararamdaman yung vibration. nang yayari yung vibration sa 600 - 700rpm - naka D o R, pag nasa N o P nasa 500rpm ko walang vibration kahit naka on ang a/c... yun naman ang normal na rpm ko dati pa.
mga sirs, pwede din bang maging reason ang atf na dahil kakapalit lang kaya ganun? parang naninibago yung transmission sa madulas na fluid? naka usap ko na yung shop pinapa balik sa akin para macheck nila, sabihin ko din mga suggestions nyo.
I trust the shop and their mechanics... nagkataon lang talagang madaming trips ngayon kaya gusto kong itry kung kaya kong ako na lang gumawa ng solusyon, pero next week if the symptom persist... balik na ako sa shop.
salamat ulit mga sirs... merry christmas. ingat! dont drink and drive.
December 24th, 2006 01:52 PM #16
Start looking for other problems then, because you said it does not vibrate when moving so it's an idling issue.
If going for engine mounts, usually there are three or four in your car. One is on each side of the engine mounted to the frame. Check that the rubber is intact and not torn, and check for play too. There shouldn't be any. There is also one sa center subframe usually, right behind and under the radiator, check that the same way. There may be another one behind the engine, near the exhaust area, but I'm not familiar with these cars so just look around.
If going for fluids, check that the transmission fluid is bright red, has no burnt smell, and is filled to the correct level. Check that the engine oil is golden, has no burnt smell, and is also filled to the correct level. If possible, do you know what kind of oil they put in?
Also, look around the engine oil filter and transmission area for any spots where the mechanic may have pulled something out of spec. There may be pulled wires/hoses/cables that may be causing your car's strong vibrations.
Of course, if you can't find anything wrong with these, bring it back to them and have them fix it. Services usually have a warranty period and you should still be able to have it fixed. If not, have them refund the money back to you and find another shop.
If they claim it's normal, it's not. There is no need for adjustment when replacing fluids if they replaced it with the correct type.
December 25th, 2006 11:49 AM #17
it doesn't vibrate when moving kasi mataas na rpm nya. pag sira na yun engine support may vib pa rin, pero minimal. bumababa yun rpm niya kasi may load na aircon, tranny when in drive. dapat kasi maintain un rpm mo kahit anung load niya. tignan mo yun idle up switch kung mayrun nito. may small hose yun minsan nagkakabutas or nahuhugot. di mo masyado mapapansin yun. pede din nag katataon nasira yun supports po, pa check mo na din. Merry Christmas to ALL!!!!
