Results 1 to 15 of 15
    May 2004
    Tips naman kung kelan dapat mag palit ng ATF. Ano ng mga signs? Thanks
    Nakow! Wag mo nang antayin ang 'signs' na yan!!!
    Basta follow a regular change schedule. eto lang magagawa mo from your end to maintain your AT.
    Usually, good ATF smells sweet. Pag amoy sunog na, then its too late..... kelangan palitan agad.
    Im not sure lang about the maintenance sched, pero the more you change it, the better. Why? kasi tuwing atf change, around 20-30% of the old atf still remains in the tranny.
    May 2004
    Thanks Pajerokid yung signs ko parang sunog na nga amoy toasted bread, yari! mag kano ba pa palit ng ATF? may filter ba to na papalitan? Papalit na ako bukas.
    May 2004
    BTW Saan pala ok magpapalit ng ATF?
    Jun 2004
    i agree with pajerokid have it changed asap especially if amoy sunog na.
    i think recommended interval is 40,000km. but for my automatic tranny equipped vehicle i change the ATF every 25,000km
    Sa suking gas station pwede na Ako sa local caltex lang.
    Feb 2004
    anong ATF ang maganda para sa AT tranny?
    Paj ATF and filter change every:
    -12 months or 25,000 km
    IF you use your ride under the ff:
    -heavy traffic where outside temp regularly reaches 32 degrees C or higher
    -in hilly or mountainous terrain
    -frequent trailer pulling
    -frequent off road
    THEN change every22,500km
    NOTE:
    -ATF should be hot when changed
    -Most models with drain plugs do not have filter-determine 1st your model to check if you need filter renewal
    Use Dexron II or Mercon ATF
    Capacity (approx.)
    '86-earlier models 3.7 ltrs.
    '87-later models 5.1 ltrs.
    Pajero Haynes Repair Manual section 39 & 1-2
    Jun 2004
    rlp1099,
    thanks for the clarification. in this case i'll change the ATF earlier, around 20,000km.
    although for my expedition last time i checked with the dealer they said 40,000km for the ATF change. hmmm...
    paj4x4
    May 2004
    Bossing, tanong ko lng po. Ano po ba recommended nyong ATF aside from DEXRON II for mitsubishi lancer?
    May 2004
    Dexron III replaces the Dexron II
    Im using MOBIL 1 SYNTHETIC ATF ever since and very satisfied.
    dbulido, where did you source the Mobil1 ATF? How much?
    May 2004
    Pinadala galing Japan ng relative kasi puro Automatic yung mga ride nya. Price is 2,382YEN 1 liter, bale mga 1,300 sa peso.
    price is acceptable, kaya lang sa japan pa kukuha
    Aug 2003
    up ko lang po ito...
    what if ordinary ATF lang ginamit mo like the one in Caltex ATF....pero sa dipstick naka sulat DEXRON II sabi kasi ng suking gasolinahan ok lang yon......
    may effect po ba?
    very erratic po kasi ang shifting ng auto tranny ko ang bilis mag shift pang nag dodownshift...pag nag oovertake ako
    may 10,000km na nakakalipas ang ngayon ko lang na experience to last week
Merged: ATF Qs
