Results 1 to 10 of 15
July 26th, 2004 07:46 PM #2
Nakow! Wag mo nang antayin ang 'signs' na yan!!!
Basta follow a regular change schedule. eto lang magagawa mo from your end to maintain your AT.
Usually, good ATF smells sweet. Pag amoy sunog na, then its too late..... kelangan palitan agad.
Im not sure lang about the maintenance sched, pero the more you change it, the better. Why? kasi tuwing atf change, around 20-30% of the old atf still remains in the tranny.
July 26th, 2004 07:55 PM #3
Thanks Pajerokid yung signs ko parang sunog na nga amoy toasted bread, yari! mag kano ba pa palit ng ATF? may filter ba to na papalitan? Papalit na ako bukas.
- Jun 2004
- 476
July 27th, 2004 02:49 PM #5i agree with pajerokid have it changed asap especially if amoy sunog na.
i think recommended interval is 40,000km. but for my automatic tranny equipped vehicle i change the ATF every 25,000km
- Sep 2003
- 287
July 27th, 2004 05:56 PM #8Paj ATF and filter change every:
-12 months or 25,000 km
IF you use your ride under the ff:
-heavy traffic where outside temp regularly reaches 32 degrees C or higher
-in hilly or mountainous terrain
-frequent trailer pulling
-frequent off road
THEN change every22,500km
NOTE:
-ATF should be hot when changed
-Most models with drain plugs do not have filter-determine 1st your model to check if you need filter renewal
Use Dexron II or Mercon ATF
Capacity (approx.)
'86-earlier models 3.7 ltrs.
'87-later models 5.1 ltrs.
Pajero Haynes Repair Manual section 39 & 1-2
- Jun 2004
- 476
July 27th, 2004 08:22 PM #9rlp1099,
thanks for the clarification. in this case i'll change the ATF earlier, around 20,000km.
although for my expedition last time i checked with the dealer they said 40,000km for the ATF change. hmmm...
paj4x4
- May 2004
- 12
August 1st, 2004 05:21 PM #10Bossing, tanong ko lng po. Ano po ba recommended nyong ATF aside from DEXRON II for mitsubishi lancer?
Monk-owned R53
