check the battery cells' specific gravity
(if it's conventional) one by one using a hydrometer (available at SM, Ace Hardware, Handyman, etc)if at least one cell's dead , that will read less than 12 v on the voltmeter which is not enough to start your battery (Cold Cranking Amperage)...if battery's ok, the starter should be brought down for bench testing the solenoid and armature assembly. check loose connections to the starter motor and / or loose mounting bolts of the starter motor.hope this helps.
