Results 11 to 20 of 22
October 11th, 2005 02:20 PM #13
Boss Edwin,
Was thinkin about that pero mukhang mas sanay na ako sa Servitek Marcos Hway eh. Baka bumili nalang ako ng needed parts sa walco then ipakabit ko sa Servitek.
Thanks.
Nico
October 11th, 2005 08:11 PM #14
I was able to buy stabilizer bushings na both front and rear - Php300.00 each
And also axle boots (replacement) inner and outer - Php260.00 each
By the way, ang included sa boot package na pang clamp ay plastic belts lang. Yung ginagamit na pang tie ng extension chords. Sabi ng walco minsan mas preferred pa daw ito. How true is this?
October 12th, 2005 08:31 AM #15
Originally Posted by Djerms
Have a nice day.
October 12th, 2005 09:08 AM #16
link end bushings at 300.00 each? that would be 8pcs in the front and sa rear also the same? so that would be 4800.00 total for the bushings?
October 12th, 2005 02:17 PM #17
October 12th, 2005 04:58 PM #18
ARB,
There are only 2 located at the front and 2 bushings at the rear. A total of 4 bushings all in.
Update ko lang. Was able to replace bushings at servitek this morning. They also replaced all my axle boots. Laki pala ng difference. Made my suspension solid again.
Beetols,
Alambre huh? Ang kuripot mo talaga..hehe.
October 12th, 2005 05:56 PM #19
October 12th, 2005 08:06 PM #20
4 x 300 = 1200. same price lang sila ng poly bushings. ball joint ang link pala ng trooper. try mo change ang stab bushings na D it will also handle a bit better.
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
