Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Guys any idea where I can get replacement axle boots and stab bushings for my trooper? Sabi sakin around 350Php lang ang bushings. Yung boots is around 400 a pc sa walco. Sa may Marikina area ako eh. saan kaya pwede bumili nito? Do you think servitek can source out these parts for me?
    By the way here are casa prices of bothe parts:
    Stab bushings 1.5k each
    Axle boots 2.8k each
    TIA
    stab bushings you are referring to are the ones that look like a letter D? you can get poly bushings for around 1.2k. change mo na rin link end bushings. replacement axle boots cheaper, mga for fwd cars usually nilalagay.
    Jun 2005
    yung stabilizer bushing - there are 2 types : stabilizer bar bushing and stabilizer end bushing. The stab bar bushing is what ARB is referring to which looks like the letter D; while the end bushings is the disc shaped bushing which sells for around P80 each not unless your stabilizer uses the stab-link (if you have stab link then you don't need the stab end-bushing).
    yung axle boot kit from the casa is usually complete with packing grease (normally color white) and ring fastener. Make sure the aftermarket boot kit you get is complete with packing grease and fastener since yung packing grease doesn't contain petroleum distillates which will melt the boots in the long run.
    HTH
    The mechanic just said that my stabilizer bushings (rear) needs to be replaced. Parang rubber bushing lang yun located at the end of a bent metal (Eto na yata yung stabilizers). Do you mean that theres another one located at the middle of this steel bar?
    As for the packing grease...thanks for the info bro.
    Update ko lang po ito. I might go to WALCO later to buy some parts. I need some clarification sa stab bushings. I want to replace all na sana (rear and front bushings) para isahan nalang. What should I say to the vendor?
    As for the axle boot, thanks for the tip. Batsa I'll have to make sure na may packing grease and ring.
    TIA
    Quote Originally Posted by Djerms
    TIA
    Hi Djerms, where is WALCO? I also need to get stab bushings and axle boot for my Suzuki Esteem. Do you have their contact numbers so I can call and ask if they have stock for Esteem? I could not find other suppliers for the Esteems except for the Casa and one store in Banaue whose price is just a little lower.
    Thanks.
    Walco is located in Banawe. Unfortunately I dont have their number. Not sure though if they have parts for your Zuk since I know that they specialize in Isuzu parts.
    link bushings is the ones at the end. the bushings looks like that of the stud type mount ng shocks, only smaller.
    most common aftermarket asle boots dont come with grease and the metal fasteners are not that good also. kaya lang mahal talaga ang orig.
    ARB,
    I think that the axle boots I had before were replacement boots na rin. Its just funny that WALCO calls them originals since they also have cheaper boots selling below 400.00.
    As for the bushings. Yup, I think that what I need are the link bushings. How many do I need in front and in the rear..2 each?
    Aug 2003
    just had my axle boot replaced at shell las pinas. meron sila replacement... around 400 nga ata plus grease. labor is around 600+, pinalitan din kasi 1 set studs and lug nuts ko e.
    graphire,
    Whats your ride?
    May 2004
    djerms, bakit di mo pa sa mototrcraft pagawa para lapit sa banawe?
    Boss Edwin,
    Was thinkin about that pero mukhang mas sanay na ako sa Servitek Marcos Hway eh. Baka bumili nalang ako ng needed parts sa walco then ipakabit ko sa Servitek.
    Thanks.
    Nico
    I was able to buy stabilizer bushings na both front and rear - Php300.00 each
    And also axle boots (replacement) inner and outer - Php260.00 each
    By the way, ang included sa boot package na pang clamp ay plastic belts lang. Yung ginagamit na pang tie ng extension chords. Sabi ng walco minsan mas preferred pa daw ito. How true is this?
    Hi Djerms, thanks for the reply. I might as well open a thread and see if there are any Tsikoters there who buy Zuk parts outside of the casa.
    Have a nice day.
    link end bushings at 300.00 each? that would be 8pcs in the front and sa rear also the same? so that would be 4800.00 total for the bushings?
    Mar 2003
    yes, those plastic belts will hold just enough...i had mine tied up with a wire (alambre) for added grip and its still intact. but yeah, i suppose those plastics are good enough basta maganda ang pagkalagay.
    ARB,
    There are only 2 located at the front and 2 bushings at the rear. A total of 4 bushings all in.
    Update ko lang. Was able to replace bushings at servitek this morning. They also replaced all my axle boots. Laki pala ng difference. Made my suspension solid again.
    Beetols,
    Alambre huh? Ang kuripot mo talaga..hehe.
    Mar 2003
    Beetols,
    ahehehe! shempre mahirap na ang buhay eh.=) pero, seriously, it works for me! so why not...
    4 x 300 = 1200. same price lang sila ng poly bushings. ball joint ang link pala ng trooper. try mo change ang stab bushings na D it will also handle a bit better.
Stabilizer bushings, Axle Boots
