it's time to replace my sparkplugs.
may nagsabi sakin maganda raw cold sparkplugs ikabit ko.
ano ba mga magandang brand and model?
ung platinum tip din pla dapat
paki indicate na rin price at san makabili
tnx![]()
tnx![]()
If your engine is unmodified, stick to what your car manual recommends. Usually NGK or Denso.
cold plugs are typically used when the engine is a high reving turbo charged engine.Originally Posted by kenet_3
Using cold plugs in a stock non-turbo engine will just result in fouled plugs when driven in daily traffic.
for the 323... the manual states that you can either use a cold or hot sparkplug.
ok ang cold plugs kapag lagi kang nasa highway / long drive. pero kung city driving ka... dapat hot plugs.
and kapag nag foul-up ang cold plugs, talagang ramdam mo.
may nagsabi kasi sakin na cold sparkplugs, meaning yung higher heat rating (tama ba?)
kasi naka-advance ang timing ko and may engine knock. cold spark plugs daw ang solusyon dun para di mag-knock
Cold plugs help in curing knock in advanced timing but it's not a necessary item.
What fuel do you use? If you advance your timing its adviced to use high octane like Petron Blaze or Velocity... or your timing is just way too advanced.
Check what your stock plug is and get the next heat range... for example if you're using an NGK BKR5E, switch to BKR6E.
mag Bosch Platinum ka na lang. Yun orig ha. may 4 tip platinum na dito pero medyo mahal.
me, i'm using denso iridiums. but my engine is turboed. so best stick to OEM spec.
BKR6E na ung rating ng stock plugs ko e, and wla na daw higher pa dun (ung BKR7E, o meron ba talaga nito?)Originally Posted by vinj
so i guess stick na lang talaga ako sa rating na un?
pero may nakita rin ako sa mga bosch plugs, may counterpart yung BKR6E na platinum tip. ok kaya un? ramdam kaya difference? P130 per piece lang kasi e![]()
The BKR7E's are very hard to find... What's your car if i may ask? On some Jap cars, the Bosch plugs dont work toowell...
bkr6e is already a cold spark plug... brk5e ang hot.Originally Posted by kenet_3
san dun sa banawe? pumunta ako dun sa tindahan na may malaking sign ng NGK, sa may E Rod side un. wla daw talagang BKR7E. pero may nakita akong BKP7E sa ichiban at sabi rin nila wala daw talaga nung BKR7E, hanggang 6 lang daw tlaga sa BKR.Originally Posted by speedyfix
try hrc. for some cars that come equipped with a 6 heat range plug from the factory, di pa cold plug yung 6.
may isa pa pala akong prob. kasi sabi nyo dito, colder pag tumataas ang number, meaning it can dissipate heat faster and remain colder. sa NGK lang ba nag-aapply yung ganung convention, kasi sa bosch nabasa ko lower higher number means hotter plug.
tnx ulit
depends on the plug maker. ngk and denso share the rating (higher is colder), pero densos heat range 6 is number 16 or 20 ata. basta check the manufacturers website for info on how they rate their plugs.
tnx sir speedyfix ;)
another question sir, will you recommend bosch sparkplugs vs ngk?
ano maganda na spark plug para sa crv??Originally Posted by speedyfix
