Results 11 to 20 of 20
November 5th, 2005 09:23 PM #11
The BKR7E's are very hard to find... What's your car if i may ask? On some Jap cars, the Bosch plugs dont work toowell...
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 7th, 2005 02:18 PM #13Originally Posted by kenet_3
November 7th, 2005 06:51 PM #14Originally Posted by speedyfix
- Nov 2003
- 3,849
November 9th, 2005 08:28 AM #15try hrc. for some cars that come equipped with a 6 heat range plug from the factory, di pa cold plug yung 6.
November 10th, 2005 08:32 PM #16
may isa pa pala akong prob. kasi sabi nyo dito, colder pag tumataas ang number, meaning it can dissipate heat faster and remain colder. sa NGK lang ba nag-aapply yung ganung convention, kasi sa bosch nabasa ko lower higher number means hotter plug.
tnx ulit
- Nov 2003
- 3,849
November 13th, 2005 11:24 AM #17depends on the plug maker. ngk and denso share the rating (higher is colder), pero densos heat range 6 is number 16 or 20 ata. basta check the manufacturers website for info on how they rate their plugs.
November 14th, 2005 07:47 PM #18
tnx sir speedyfix ;)
another question sir, will you recommend bosch sparkplugs vs ngk?
- Nov 2003
- 3,849
- Aug 2003
- 91
November 16th, 2005 10:01 AM #20Originally Posted by speedyfix
Thank you!
