Cold plugs help in curing knock in advanced timing but it's not a necessary item.
What fuel do you use? If you advance your timing its adviced to use high octane like Petron Blaze or Velocity... or your timing is just way too advanced.
Check what your stock plug is and get the next heat range... for example if you're using an NGK BKR5E, switch to BKR6E.
