Results 1 to 18 of 18
    anong okay na spark plugs para sa Honda Civic SiR? B16A engine. aside from the stock ones and the ones on the owner's manual, what others are okay? kindly give the number rin para di mahirap bumili hehe
    may nagsabi ksi dati na bosch daw di masyado compatible with honda engines? yung NGK daw mas bagay? hehe thanks
    If you have money to burn, try the iridium plugs either from denso or ngk.
    Nov 2003
    iridium will always be good but since they have a self-cleaning temp, kung di masyado modified yung sasakyan mo it might foul easily.
    if you're ride is stock or semi stock, i'd suggest sticking with the stock plugs. just change them everytime you change your oil to ensure they are still functioning properly
    galing ng mga sagot ni speedyfix! Kung stock or mostly stock ang makina...K.I.S.S.
    keep it stock.....
    kung pa ng isang "S" sa K.I.S.S..... "stupid" ba iyon? hehehe :D
    even an engine with stage 1 mods (no ignition mods) would perform well enough with stock plugs. Have them changed every tune up or oil change. They're cheap to replace anyway.
    Jan 2004
    agree to that... ako i was thinking the same thing, (balak ko rin magpalit ng spark plugs) stock engine ang akin (Civic 1.5 LXi), pero naisip ko baka lumakas lang sa konsumo ng gas. Kaya i-stick to stock spark plugs na lang.
    Dec 2003
    denso iridium ik16 sa vti ko before, ok yan sa SIR i think..
    hahaha. actually, shithead yon hahaha
    my Integra GS-R B18 Spec for non-honda gearhead
    DC Sports 4-2-1 Header
    K&N SRI
    GReddy cat-back exhaust
    Spoon Camgears
    it didnt make any power with Iridium after getting dyno-tuned. Iridium is over-rated for almost stock engine. Work with your internals, dyno tune, ignition upgrade, then lap them Iridium. Maybe, just maybe, you'll see a bit of a gain.
    may nagbasa pa nga ako ng stock plugs is better kse they conduct more electricity 9copper di ba?) as opposed to Iridium using the simple DC electricity theory.
    quote:
    "... I've gotten better power out of the Iridium plugs..."
    Assuming they're both gapped properly, iridium plugs CAN'T give
    any more power than regular copper plugs. They just "spark." How MUCH they spark is a function of the gap and the coil. How
    WELL they spark is a function of their condition. It has nothing to do with copper vs. platinum vs. iridium. The exotic materials just
    last longer -- they don't erode as quickly. If it SEEMS like you're getting more power out of iridium plugs,
    it's because your old plugs were shot. ANY properly-gapped new plugs would have given you the same improvement.
    Nov 2003
    great replies guys! also, don't fall for the 4 tip or twin tip plugs. in my experience, wala masyado difference ito from stock. just keep the cheap plugs in good condition by replacing them every time you have PM performed and you will be more than happy with their performance
    uhn medyo im looking for longer lastin ones na eh
    ..di naman yung mayado matagal..ksi i dont think its really necessary to change them every 5000 kms or 10000 kms.
    pero okay na rin cguro stock..saan ba sure meron?
    Keep the stock plugs and change every 10K-15K.
    You can get better response/performance gains by advancing the timing a bit and switching to high octane IMO.
    Dec 2003
    lahat ng plugs may self cleaning temp. ang denso iridium, eh copper core din. the difference is the tiny electrode which means that it needs a lower voltage for the spark to bridge the gap. application nito sa normal driving? maaring wala. mas maaapreciate mo ito kung turbo charged ka dahil mas dense ang laman ng cyllinder kapag naka turbo which makes it more difficult for the plug to spark given the same voltage.
    Plus, mas matagal ang change interval ng mga exotic metal na plugs. pero, given the price, mas makakatipid ka pa din kung bumili ng normal na ngk at palitan ito every oil change.
    diba may iba't iba't rating tong mga plugs na to? i think sa number.. 4 5 or 6.. number five yata pang slightly mod na car dba?
    the numbers is heat range of the sparkplug.
    so ano dapat? 4 ba yung para sa mga turbocharged or 6? malamang 5 na yung dapat gamitin ko diba?... and ano ulit yunf pag may letter "R" sa code? mas okay ba kunin yung may "R"? or pareho lng? hehe thanks!!
    Nov 2003
    usually parehas lang yung may R sa side. 4,5 & 6 heat range plugs are pretty much for stock engines. you only go to 7-9 heat range if you have more serious mods on the engine like high compression, NOS or a turbo/super charger.
    even casa will recommend changing plugs every oil change so i don't think going 10-15T kms will be advisable. remember, if you plugs are fouling na and not in the best condition, you gas milage and performance will suffer as well. replacing plugs at normal intervals is cheap and simple preventative maintenance for your engine!
    okay! hehe!
    well said!!
Spark Plugs
