Page 1 of 2 12 LastLast
Results 1 to 20 of 27
  1. #1
    NGK, Bosch, or Denso? I going for the platinum tipped... mahal kasi ng iridium. Or do you have other brands to suggest?
    Dec 2003
    bosch...proven and tested quality throughout the ages.
    If you're changing to platinum or so... stick to the brand and model thats recommended by the owners manual for the engine of your car. NGK, or DEnso are usually the choice plugs of Jap manufacturers.
  4. #4
    Manual doesn't specify any brand. Mitsu Adventure ride ko... I heard ok daw NGK. I used the iridium plugs for the last 20K Kms. not much difference in performance, not sure about the fuel consumption.
    ano po magandang spark plugs for revo 2.0
    magpa 10K pms ako this coming saturday sa casa... NGK lang ilalagay nila...
    not in the manual? kindly recheck...
    for both my vehicles (323 & rav4), they specifically stated the exact brand and model to use.
    for the rav4, it came with an OEM denso iridium SP that will last for 100k. an aftermarket iridium SP will only last for 20k.
    for the 323, am using NGK cold plugs.
    Sa LXI Civic ano kaya? Wala na kasi ako manual eh.
    Right now im using platinum Bosch. Ok naman sya
    Jul 2003
    sir mazda talaga?? hanggang 100K ang iridium ng rav4 mo? hehe ako nakadalawang palit na 30K palang i dunno pero sabi kasi ng adviser eh.. but its only 300++ per set
    P300 per set of 4?
    ang mura naman niyan for iridiums... ang alam ko P600 per piece ang iridiums natin...
    basahin mo sa manual... 100K ang nakalagay for SP
    Aug 2003
    iridium sparkplugs will only matter if you use high-tension wires right?
    Mar 2004
    splitfire sulit cya. its expensive but it lasts longer than the usual spark plugs
    meron ba spark plug na okay performance na hindi iridium type.. kahit palit every 10TKm or 15TKm?
    stock kasi ng revo eh NGK gamit, baka meron slightly higher na good spark plugs
    for toyota vehicles use denso plugs.OEM ng toyota yun.
    Aug 2003
    revogsx,
    i agree with nikko m, pero base lang to sa experience ko nung nagpapalit ako noon sa marc caltex nina sir chieffy. ride ko dati e revo gl gas
    denso yung ipinalit and nagimprove yung hatak, di rin naman sya mabilis nasira, di pa gaanong mahal. di ko na nga lang alam kung ano yung exact model nung plugs na yun.
    Dec 2002
    There's NGK iridium for about P330 each, it's called Laser Iridium and comes in a box of 4 pcs.
    The model for a standard BKR6E-11 is a IFR6T-11. Haven't tried it though.
  17. #17
    Plugs for Nissan X-Trail? Denso or NGK? It says in the Manual:
    Standard -> LFR5A-11
    Service Option -> LFR4A-11
    Service Option -> LFR6A-11
    Iridium ba to?
    NGK BKR5E-11 (NGK "R") for my SX8 City
    Palit ako every 5,000 kms. Ok lang mura naman eh
    Iridium ba to?
    pag may -11 sa last part ordinary type lang yan.
    For my ride I use NGK GP platinum. (NGK ZFR5F-GP) Php145 isa sa aerodynamics sa masangkay binondo.
    Dec 2002
    Based on NGK catalog, a LFR5A-11 means:
    L- plug type, thread reach 26.5mm
    F- shell size, 14o x 19mm, 16mm hex
    R- resistor
    5- heat range number
    A- special design
    11- spark gap, mm
    This is a standard plug since iridium plugs starts with I or IZ, platinum with P, PL or PZ. The LFR6A-11 is a colder plug for long, fast hiway use.
Spark Plug Choices
