If you're changing to platinum or so... stick to the brand and model thats recommended by the owners manual for the engine of your car. NGK, or DEnso are usually the choice plugs of Jap manufacturers.
Manual doesn't specify any brand. Mitsu Adventure ride ko... I heard ok daw NGK. I used the iridium plugs for the last 20K Kms. not much difference in performance, not sure about the fuel consumption.
Originally posted by ILuvDetailing Manual doesn't specify any brand. Mitsu Adventure ride ko... I heard ok daw NGK. I used the iridium plugs for the last 20K Kms. not much difference in performance, not sure about the fuel consumption.
not in the manual? kindly recheck...
for both my vehicles (323 & rav4), they specifically stated the exact brand and model to use.
for the rav4, it came with an OEM denso iridium SP that will last for 100k. an aftermarket iridium SP will only last for 20k.
sir mazda talaga?? hanggang 100K ang iridium ng rav4 mo? hehe ako nakadalawang palit na 30K palang i dunno pero sabi kasi ng adviser eh.. but its only 300++ per set
Originally posted by pissword sir mazda talaga?? hanggang 100K ang iridium ng rav4 mo? hehe ako nakadalawang palit na 30K palang i dunno pero sabi kasi ng adviser eh.. but its only 300++ per set
P300 per set of 4?
ang mura naman niyan for iridiums... ang alam ko P600 per piece ang iridiums natin...
i agree with nikko m, pero base lang to sa experience ko nung nagpapalit ako noon sa marc caltex nina sir chieffy. ride ko dati e revo gl gas
denso yung ipinalit and nagimprove yung hatak, di rin naman sya mabilis nasira, di pa gaanong mahal. di ko na nga lang alam kung ano yung exact model nung plugs na yun.
There's NGK iridium for about P330 each, it's called Laser Iridium and comes in a box of 4 pcs.
The model for a standard BKR6E-11 is a IFR6T-11. Haven't tried it though.
Originally posted by ILuvDetailing Plugs for Nissan X-Trail? Denso or NGK? It says in the Manual:
Standard -> LFR5A-11
Service Option -> LFR4A-11
Service Option -> LFR6A-11
Iridium ba to?
pag may -11 sa last part ordinary type lang yan.
For my ride I use NGK GP platinum. (NGK ZFR5F-GP) Php145 isa sa aerodynamics sa masangkay binondo.
Based on NGK catalog, a LFR5A-11 means:
L- plug type, thread reach 26.5mm
F- shell size, 14o x 19mm, 16mm hex
R- resistor
5- heat range number
A- special design
11- spark gap, mm
This is a standard plug since iridium plugs starts with I or IZ, platinum with P, PL or PZ. The LFR6A-11 is a colder plug for long, fast hiway use.
