i saw some car owners apply insulation sheets right after a washover job. they apply them just before replacing the carpets and the other interior stuff. it looks crude but i suppose it does the job effectively.
and i think they also apply this on the roof of the car just before installing the ceiling lining so as to reduce heat transferrence too.
if your car is a charade. sound deadening would not help in killing the sound you hear.
the design of the charade,and cabin is full of opening where sound or air can get into the cabin.
if it has something to do with your tires, its even much worst. theres a opening from the wheel wells that is located near your door hinge. the only thing that separates you and the tires through that opening is the rubber that arches along the wheel well.
applying flashband would not help unless you plug that hole with flashband. save yourself 3k or so by not applying flashband on the doors, cabin floor etc etc
I should know, i have done the same thing on the same car sometime ago.
mga sirs yun po bang flashband yun po b yng makintab n kinakabit sa mga bubong ng bahay para maka reduce ng init tama po b ako kasi pwede ko n po gwin kagad kc nakatangal yng carpet ng kotse ko ngyn thanks po sa mga magiging reply nyo hehehhe
docpete:
thanks for your reply po bibili po ako bukas sa mga nag aaircon nun hehehehe,para mas mura yung presyo,,pwede b lagyan pati yung mga likod ng pinto mga ilang patong kaya para wla tlagang sound heheheh puwede bang i rugby nlng???
i just did my front doors last weekend. kapagod!
but it's well worth it. bukod sa nakita ko ang loob ng mga pinto ko,
nalinis ko na din at nilagyan ko na ng flashband. actually hindi nga Evostik Flashband ang nabili ko eh. Flashingtape yung nakalagay at iba ang tatak.
akala ko yun na yung flashband eh. pero same din naman ang function nun.
mas mura ang flashband na nakita ko sa SM Ace sa makati. gupitin lang ng
maliliit na piraso para mas madaling idikit. dapat tuyong tuyo ang didikitan.
isang roll lang ng tape ang nagamit ko for both doors. may isang roll pa ako.
baka sa rear doors ko ikabit. para dun sa "masarap" na tunog pag sinasara. hehehe . . .
