Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Tanong ko lang, kasi yun fog light socket ko naputol yun wire sa loob, so i had it soldiered twice na and parati natutunaw yun sinoldier na part. Meron bang ibang material na dapat gamitin to fuse the metal and the wire? Nagatanong kasi ako sa ACE kung meron mighty bond type na glue na conductive pero wala naman sila. Any help would be greatly appreciated. Thanks.
    Jul 2005
    Baka solder ang ibig mong sabihin... Kung natutunaw, splice mo na lang. try to tie the broken part with solid wire after mo splice para mas matibay
    Feb 2005
    Hindi kakayain nung ordinary solder yung heat na gine-genarate ng foglamps pag bukas. Kapag naka-on yung fogs mo for, say, an even ten minutues eh it can generate enough heat to start melting the solder lead. The best thing to do IMO is either splice the wires (gaya ng sabi ni Maykel) or buy male and female connectors to join the wires.
    Aug 2004
    same suggestion as nicolodeon, mas maganda nga bili ka nalang ng connectors para matibay talaga yung connection ng wires.
    it shouldn't heat up that much...you might burn your car...if it is hot enough to melt lead/tin solder what more ang rubber???
    Suggest ko i-check mo ang wire thickness (resistance), present ba ang fuse (tama ba ang Amperage), and did you use relay...baka merun mali.
    Jun 2005
    Quote Originally Posted by mcbry
    This is the best thing to do.
    Sep 2005
    E36 foglamp ito, right? Where did the connection break?
    If the break is on the socket pin
    1a. I think your problem is "cold" soldering and not melting. If the heat is enough to melt the solder on your wire, the plastic socket would've melted before that. Ordinary soldering pens (about 30watts) are not enough to make a good solder since the socket pins are a bit thick. A 60watt pen or gun should do the trick. Cold solders result from insufficient heat when soldering and usually breaks off.
    1b. Kung hindi pa rin pwede, just replace the wire socket with a new one. Pwede naman tanggalin yung luma. Just seal it up good for weatherproofing.
    If the break is on the bulb socket
    2. Mas problema ito, but still fixable. If the break is the pin where you connect the negative wire - it is the bulb mount itself and cannot be soldered. I suggest that you just convert the bulb and socket to H7 so you can connect the negative wire to the bulb itself.
    HTH
    go to any radiator shop at dun mo ipasolder... or a jewelry shop.... same principle lang ginagamit nila.... have already done this and still snag fit and fine for so many years....
    hehe...akala ko sundalo.
    Jun 2005
    tingin ko din cold solder yan kaya natutunaw... hindi maganda ang pagkakahinang pati yung kinakapitan ng lead. before trying to solder, twist mo muna yung dalawang wires with each other tapos dun mo ihinang. habang hinihinang, lagyan mo ng lead pero after mo dun sa lead, iwan mo ng mas matagal yung panghinang sa wire. about 1-2 sec. para "maluto" ang hinang.
    Aug 2005
    akala ko ko soldier.. hehehe.. Yeah maganda talaga kpag matibay lahat
    StraightSix. thanks for the pic. Solder nga, mali ako hehe. My problem is 1A. Pinatingin ko na sa electrician pero alanganin ako kasi nung pag bukas nya ng hood, ang unang tanong nya e nasan yun battery? hehehe... Dadalhin ko na lang siguro ito kay Alex ulit. Sabi nung electrician parang di daw kumokontact yun socket mabuti kaya umiinit ng ganun e. Yun fog light ko sa kaliwa ok naman, and yun kanan lang talaga yun malaking problema na ayaw maayos. Thanks sa advice.
    napeke rin ako akala ko sundalo hehehehe.
    probably loose contact yan kaya umiinit yung connection. the bulb's heat itself won't melt the solder lead. pwede mo gamitan iyan ng soldering paste para maganda ang kapit. hayaan mo lang na maluto yung lead tapos lumamig ng normal. for additional strength may soldering solution (forgot the name) na ipinapahid sa soldered parts para may coating sya.
    Feb 2005
    Quote Originally Posted by jim
    yes, but the current flowing on the wires can (depending on the kind/type of solder done).
    funny! hahaha!
    Hindi naman ako marunong mag solder e, pinagawa ko lang, and after the second time kala ko ok na, natunaw pa din talaga, maybe the electric current is generating too much heat for some reason.
    Nung sinabi nung electrician nasaan na yun battery gusto ko na ibagsak yun hood at umalis na dun e. hehehe.
    Feb 2005
    Quote Originally Posted by seonadancing
    Abay baka electrician na pang celfone yan.
    Jun 2005
    Quote Originally Posted by finchy18
    I remember nung NROTC namin. Our platoon leader commanded, "Right Soldier, Arm!". Sir, sagot nung isa, baka shoulder.
    Sep 2005
    Take it to someone who knows better how to solder
    Poor contacts because of dirt, loose connection, corrosion or cold solder will definitely cause more heat than what's normal. That's because there's less conductor for the current to flow through. So I suggest you have the plug and socket cleaned, too.
    Yung electrician ... ahem, baka hindi napansin yung pouch ng baterya (4cyl). Kung 6cyl naman, OK lang at baka first-timer ... marami talaga ang hindi nakaka-alam na nasa trunk ang battery.
    Sep 2004
    Quote Originally Posted by j_avonni
    Hehehe...sorry, OT, pero couldn't help myself...
    nung summer ROTC namin sa Ft. Boni, talagang mga sundalo nag-train sa amin...pinagtripan nila yung mga bading na nag-ROTC (utility brigade kasi, tagatinda ng hopia at softdrinks sa ibang kadete)...pinaform sila ng platoon, tapos tinawag yung pinamatangkad na bading...
    "You! Give them the command to salute! On the double!"
    (Correct command should be: "Pugay kamay...na!")
    Nag-alanganin sya, mukhang di nya kasi alam. Di rin naman nag-salita yung ibang bading out of fear...
    So nagalit yung sarhento. "I said give them the command to salute! Demmit!"
    So, sabi ng matangkad: "Saludo na!"...
    And here's the kicker, almost half of the gay platoon actually saluted!
Soldier.
