Results 1 to 10 of 10
    Oct 2004
    guys help naman, I am in need of starex surplus parts....ang kailangan ko are Camshaft Bearings 3&4. do you know where I can get surplus parts? mahal kasi gagastosin ko if I buy new ones kailangan pa daw ipa-machine shop kasi di kasya? Help naman please! Thanks.....
    Sure ba na magkakasya ang surplus? Bakit ang original, hindi? Medyo intensive work yan, are you sure you want to compromise?
    Oct 2004
    Otep kasi daw yung bago, i'm guessing is for the new starex masmalaki daw so kailangan hasain daw ng konti, my starex is 2001 model so sabi nila hindi swak ang bago sa lumang camshaft....this is also known daw as camshaft cap.....guys baka meron din kayo ma-re-refer na machine shop that can do the hasa...Thanks
    Jun 2005
    kunin mo yun pyesa,dalhin mo sa binondo o blumentritt. pahanap ka ng equivalent na bearing. for sure may katapat yan.
    Dec 2003
    critical part wag mo dapat kuripotin..
    May 2005
    along kitanlad near banawe there is a korean surplus shop.
    Aug 2003
    doesn't one of the well-known tsikot members sell bearings? i forgot his handle..
    May 2005
    Quote Originally Posted by orly_andico
    si sirUNGAS (HEADMODERATOR)yata
    Ungas imports bearings.
    You should find a part for a 2001 Starex then. 10-15 years ang typical na mandated product support for a vehicle sa ibang markets so malamang may correct part pa din para sa iyo. Basta tama ang part number.
    Oct 2004
    Calling Ungas...bossing....baka may parts ka diyan hehehe....Thanks....Yeah bluebimmer is correct...its a critical part, if not done correctly or fitted correctly it may cause damage to other parts...actually this all happened kasi yung timing belt daw naputol which was caused by an oil leak....grabe sunod sunod ang damayan....hehe...
Starex surplus parts....help!
