Results 1 to 10 of 15
August 23rd, 2006 03:49 PM #3
sir david: simula dun sa may nakalagay na P-R-N-D-2-1 hanggang sa lever mainit lalo na pag long drive.
ano kaya dahilan?
August 23rd, 2006 04:00 PM #4
have you checked your a/t fluid lately? baka kulang na. most probably drain and replace your a/t fluid.
August 23rd, 2006 04:13 PM #5
AT fluid yun. The heat probably comes from ATF heating up in traffic.
It's easy to check your fluid level... the dipstick is low and on the left side of the engine bay. Also check for impurities and contaminants.
August 23rd, 2006 05:08 PM #6
Tingin ko din lack of ATF or expired na ATF mo...
Or pwede din barado ang oil cooler mo?
August 23rd, 2006 05:34 PM #7
That's relatively easy to check... the ATF cooler on the Sentra is built into the radiator. At least for my Sentra (B14, 2000 model)... I'm not sure if the ECCS was the same, but since the engine is the same, it's possible.
August 24th, 2006 10:17 AM #8
Good day mga sir
thank you for your inputs!
narerepair ba ung oil cooler o bili na ng bagong assembly?
mga magkano kaya?
August 24th, 2006 03:22 PM #9
The cooler is part of the radiator. When you go to a radiator repair shop, you can have them look at it, too.
At the age of the car, a new radiator isn't such a bad idea, as the newer Nissan radiators have two rows (better cooling) but you have to specify that it's for an automatic.
But first things first, check your ATF level.
August 24th, 2006 05:33 PM #10
Do you, by any chance, put the shifter into N when in stop and go traffic? Some people have this habit, and it's not good for the transmission.
As per above, have the fluid checked first. If it's OK, have the cooler lines checked. The cooler lines run to the radiator as others said, it's part of the cooling system.
yung akin naman... you can add the reverse cam and back-up sensor... pero ADAS - I don't think...
All New Toyota Corolla Cross
