Results 1 to 8 of 8
July 18th, 2007 02:09 PM #1
Hi! 1st post here, and also quite a newbie to driving.
Whenever I go downhill with the car at 1st gear, it has a tendency to just suddenly go to neutral. It doesn't always happen, but it's quite dangerous, and I've read here that going down at a low gear is safer than just using the brakes.
Another thing too, after an injector recalibration, the engine now loves to spew out black smoke, even if I try to really be easy on the gas, there's still black smoke.
Ano kaya to. Dati kasi puti lang e.
tapos sana naman hindi sira transmission nung auto.
any ideas?
- Jan 2007
- 187
July 18th, 2007 02:49 PM #5
baka sliding na clutch mo, calibrating na pump mo.. ranger yan most likely manual yan...
July 18th, 2007 03:27 PM #6
yep. manual. Ang nangyayari may tutunog tapos, biglang nakaneutral na, then bubulusok na ko pababa.
Hindi nakakatuwa pag nangyayari sa isang jam-packed carpark
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 19th, 2007 08:37 AM #7mausok talaga yan... pero if wala sya usok before the calibration then it's probably faulty work...
July 19th, 2007 10:17 PM #8
I guess hinay nalang sa apak, it's not that bad if di naman fi-nloor yung gas.
Some people told me that the trannsmission going out of gear was "perfectly normal", though.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
