Results 1 to 8 of 8
July 18th, 2007 02:09 PM #1
Hi! 1st post here, and also quite a newbie to driving.
Whenever I go downhill with the car at 1st gear, it has a tendency to just suddenly go to neutral. It doesn't always happen, but it's quite dangerous, and I've read here that going down at a low gear is safer than just using the brakes.
Another thing too, after an injector recalibration, the engine now loves to spew out black smoke, even if I try to really be easy on the gas, there's still black smoke.
Ano kaya to. Dati kasi puti lang e.
tapos sana naman hindi sira transmission nung auto.
any ideas?
- Jan 2007
- 187
July 18th, 2007 02:49 PM #5
baka sliding na clutch mo, calibrating na pump mo.. ranger yan most likely manual yan...
July 18th, 2007 03:27 PM #6
yep. manual. Ang nangyayari may tutunog tapos, biglang nakaneutral na, then bubulusok na ko pababa.
Hindi nakakatuwa pag nangyayari sa isang jam-packed carpark
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 19th, 2007 08:37 AM #7mausok talaga yan... pero if wala sya usok before the calibration then it's probably faulty work...
July 19th, 2007 10:17 PM #8
I guess hinay nalang sa apak, it's not that bad if di naman fi-nloor yung gas.
Some people told me that the trannsmission going out of gear was "perfectly normal", though.
Suzuki JIMNY [merged threads]
