Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Jan 2004
    this may sound odd.. dumb (?) [wag naman sana, nagtatanong lang po]
    i was used to starting my car with a little delay.. like.. you insert the key, twist it once, then lights, and everything (electrical) goes up, then maybe about 4-6 seconds, i start ignition.. one person told me that this is no good.. di naman daw diesel ang sasakyan so... so anyway.. is this bad? with the pause before ignition? or talagang kelangan na start agad (turning the key to I then II immediately?
    in our 323, when you put the key in the start position, it will beep for a few seconds. naturally I don't start the engine until the beeping stops.
    Jan 2004
    in my car... beeping starts kasi it checks all the other thingys in sensors, airbags, stuffs like that, then beeps (lastly) that the seatbelts are not fastened.. i dunno if there's a difference in pausing and just starting it rightaway.. i start ignition when the beeping stops..
    Jul 2003
    hehehe ang galing nito.. i sometimes do that para lang macheck ko kung off ba aircon ko and everything bago ko start talaga...
    Jan 2004
    so is there any 'bad' effect when pausing before ignition?
    Aug 2003
    Quote Originally Posted by mazdamazda
    bro bakit yung 323 ko wala na kong beep naririnig. as soon as i position key to II i'll hear hums and lights on indicators sa dash. I dont start it right away... minsan kasi parang hirap mag-crank pag start agad. I dont know advantages of starting right away and delaying it. others.. pls enlighten. thanks.
    Aug 2003
    pausing for a few seconds lets the fuel pump pressurize the fuel system. in my experience, not pausing may cause harder starting.
    doesn't make a difference. parang *** yan...either isaksak mo at i-start kaagad, o medyo i-tease mo muna ng konti...ganun pa rin yung outcome :lol:
    Jan 2004
    I don't see any problem with either method unless it is strictly specified in the operating manual. Kasi pag-start naman papatayin halos lahat ng devices sa current draw ng starter.
    basta ako, the following procedures work:
    a) Put in the key
    b) Take a deep breath three times.
    c) Close eyes for around 5 seconds.
    d) Turn on the ignition.
    wala namang adverse effects sa oto ko. although after i do step d, medyo inaantok and relaxed na relaxed ako....
    hinihintay kong mawala yung airbag light or the key bonger stops hehe
    Dec 2003
    i wait till the last of the warning lights disappear, last one is the CAT, before starting the engine.
    Quote Originally Posted by orly_andico
    Same here, my car hardstarts if i crank it right away sa unang start of the day. If I leave it on "on" for a couple of secs, it starts easier.
    pag nawala na yng check engine light...usually 2-3 sec. pag on ng switch cya nawawala, ewan ko bat pag dire-drecho ko start antagal mag crank...
    Jan 2004
    sabi kasi nung isang nakakita sa akin nung nag start ako ng auto... eh baka .. masusunog daw yung sa may ignition part??? kaya ko tuloy natanong ito eh.. di naman daw diesel ang auto so bakit kelangan painitin? the kelan ba mag engage yung mechanism sa pag start? once ur on "I" position? o pag nag ignition ka mismo?
    Jan 2004
    on a new car.. parang walang difference.. i mean.. i had my old car (pizzapie 97), and when i was learning how to drive, i was told to hold on for a few seconds.. then boom.. ignition!
    Jun 2005
    Quote Originally Posted by mgbrillo
    sabi kasi nung isang nakakita sa akin nung nag start ako ng auto... eh baka .. masusunog daw yung sa may ignition part??? . . . . .
    yup, meron possibility masunog yung ignition coil mo (kasi mag o-overheat kung matagal). On current gas engines, you only need time to prime the fuel system (i.e. pressurize your fuel rail), and during this time, your ECU does a quick diagnostic check.
    Jun 2005
    kapag ignition coil pa yung ginagamit at matagal mo iniwan sa "ON" yung ignition switch pero di mo naman pinaandar and kotse, pwede masunog yung ignition coil. this happens pag medyo matagal na ding naka-"on"
    May 2005
    ako i wait for the CEL to turn off before starting the engine... works fine for me...
    i do the same with mazdamazda. . pero ngayon, i wait til my HU goes out fully ;)
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
whats the right way to start ur car?
