Results 1 to 10 of 10
    Sep 2017
    good day mga sir, paki check po yung image, ganyan po kadami yung tubig na lumalabas kapag unang start sa umaga. dati patak patak lang po, ngayon po andami na. tapos pansin ko medyo humina hatak. sobrang bagal nya kapag simula ng takbo, tapos kapag umabot na sa 20kp/h biglang bulusok andar. patulong naman po mga sir. salamat po! Mitsubishi Dingo matic po ang kotse.
    Quote Originally Posted by echikuo07 View Post
    that's just water condensate, from the exhaust gases from the previous trip.
    that's normal, po.
    about the other problem... the water condensate has nothing to do with it.
    look for another problem, po.
    Masyadong na-aroused! 🤣
    Sep 2017
    that's normal, po.
    ahh ganun po ba, mabuti naman po kung ganun. nagulat lang po kasi ako bakit sobrang dami haha, salamat po sir
    hahaha baka nga po kaya nagbasa ng husto haha
    Feb 2009
    Simple high school chemistry
    Fuel ( HC or hydrocarbon) + O2 (oxygen)=H2O+ CO2 in ideal conditions.
    Of course other factors come in, the five gases coming out of the tail pipe:
    CO2
    O2
    CO
    HC
    NOx.
    how old is the vehicle?
    Dec 2007
    Sir are you trying to imply that he the vehicle is old, hindi na pwede ma-arouse? [emoji16]
    Sent from my ASUS_Z012D using Tapatalk
    Dec 2017
    While it is true that the presence of condensate is normal, excessive water coming out from the exhaust pipe could mean that the cylinder head or engine block is leaking. The jacket water will be ejected through the exhaust manifold as you run it and collected somewhere once you stop the engine and then when you start it first time in the morning, you'll see the condensate. You can verify this if the coolant level in your radiator is decreasing. Otherwise, everything should be normal except for your last concern about sudden acceleration.
    Sep 2017
    CO2
    O2
    CO
    HC
    NOx.
    uhm 5 years from the first owner, then almost 7 months now as a second owner sir. this is from subic, japan car.
    as of now sir i haven't checked or noticed much about the coolant level, so i will start to check this starting tomorrow morning. thank you everyone for your help.
    Jan 2018
    normal ln po yan sir,
Madaming tubig na lumalabas sa tambutso
