Originally Posted by
17Sphynx17
Yes, that would be best as it is the simplest test to check kung oblong talaga.
On another note, if hindi nga oblong and the wiggling is prevalent in the front at speed, have the guys try and check if it could be a worn out ball joint for the front tires or it could be worn out/damaged steering column/rod connecting to the tires causing the wiggling.
This is what causing "wiggling" in our l300 FB rather than tires more often than not.
Hope that helps.
