is there any maintenance procedure for servo kits? balita ko medyo sirain yun ganyan ng mitsu. was jus curious if there is a proper way of maintaining the servo. thanks!
sir, ang nasisira dun sa servo ay yung gears dun sa loob. IMO, you can't clean the gears unless you disassemble the whole servo, which is a delicate procedure becuase it takes a computer to calibrate the servo.
palagay ko disposable yung servo. Some shops in banawe sell servo repair kits but I had mine totally replaced sa casa. Mga 10k din yun including the labor.
sir artpogi::: tama ka rin. :D
i had my servo assembly replaced at the casa because the gears looked delicate and upon advise of my father, have it calibrated.
I believe that if the servo kit is properly installed, it woudn't need cleaning because the gears on the servo are inside and aren't exposed to the elements. But then again sir, it's just me.
Right again sir, the servo controls the engine when idle. so you would know that the servo needs replacement when your idling is erratic.
