Results 1 to 7 of 7
    Sep 2002
    occasionally i hear a loud screeching (sounds like metal on metal) when i start the car after a few days of non use.
    sometimes there is no screeching until i turn on the a/c.
    goes back to normal after 30 seconds or so.
    what could be the reason for this?
    2000 cefiro, about 102000 kms, had service done at around 100k.
    any place where i can get this checked besides gallery on libis (heard not so pleasant things and had strange experience there)
    tia.
    Jan 2009
    I'm about 98% sure that it's belt slippage. 2% could be the idler pulley bearing.
    Nov 2007
    Quote Originally Posted by dx8976 View Post
    tia.
    Try Speedyfix along Shaw Blvd. beside Puregold, I agree with the poster above that it might be the bearing, also check the condition of the fan belts (aircon, alternator and power steering). Good luck.
    +1 here... belt slippage.....
    Sep 2002
    is it very important to get this looked at right away?
    Sep 2005
    sir try mo pag umingay uli basain mo ng water ung belt pag nawala belt na nga po prob.
    Jan 2009
    Not necessarily if you can tolerate the annoying noise it makes. But it is recommended that you have it looked at as it could be a sign of a loose or worn-out belt. If it's the latter, it could snap any time and put you in an inconvenient situation.
screech on cold start
