Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    good evening po mga mates, may problem po kasi ko sa kotse ko, naputulan po ng timing belt ang simula ng sira ng sasakyan, pinagawa ko po overhaul daw ng valve ang gagawin, so naayos naman nagamit ko napo, ang problema naman ngayon mabilis maubos yung engine oil, may kinalaman ba yung pag overhaul ng valve dun? kasi dati hindi naman nagbabawas ng langis,..
    Sep 2006
    Yes may kinalaman ang pag overhauled ong heads mo,Maybe it's your valves not seating right or valves seals,puwede ring head gasket not properly mating with the block.Bring it back to your mechanic or whoever did it.
    salamat sir, napansin ko rin medyo malangis na yung tambutso ko..nung binalik ko sa kanya, sabi piston ring na daw..overhaul naman daw makina ko..ang pinagtataka ko lang dati ok naman bago maputol ang timing belt..may posibilidad ba maapektuhan yung piston ring sa pagkaputol ng belt??
    Nov 2003
    your mechanic should have checked it when he opened it up. that's a lousy job kung di nya nasabi sayo yan dati.
    sir usually ba ilang months ang warranty ng mga car service center? kasi kababayad ko lang ng 25k, para sa overhaul ng valve, tapos penepresyohan naman ako ng 30k para sa overhaul ng engine..
    Sep 2006
    Quote Originally Posted by renfox View Post
    In the first place dapat ayan ang tinanong mo bago mo pina overhaul.Kung sa malaking service center,ask the manager and tell your story.Do not shell out another 30k sakanila. Get your 25k and get a suplus engine.
    Aug 2006
    A valve could of gotten bent when the t-belt snapped on you... what you should do is ask the mechanic what cylinder/s he touched at all, then get a leakdown test from another shop, which will tell you where the problem is, i.e. piston rings, valves, etc, or wherever you have a leak on. If the problem is in one of those, you can get back to the shop who did the job and have them re-do it... I don't know if that's how it might work there in the Phil, but hell that's a no-no here in the US, customer service own the shops, if they don't do the job right, there's no way they're gonna refuse to re-fix it, otherwise we'll see each other in court...
    Other things you might have to consider is checking for leaks yourselves...
    Get a gun, shoot your mechanic , JK LOL... He's after your money. He didn't know how to work on the car right, or how to fix the problem, he probably just assumed that what he did will fix it, and haven't solved the same problem before...
    GL
    Aug 2006
    btw, I hate ****ing dumb ass mechanics...
    pa compression test (dry and wet) mo na lang muna para malaman mo kung rings nga or valves ang me diprensya. then kung valves nga i-pa back job mo sa gumawa without spending a penny
    Aug 2006
    a leakdown test will tell you more than that, and in details...
    Aug 2006
    I also wanted to add... there is that method we call "dollar test"; you take a dollar (doesn't necesarrily have to be a "$" bill, but you get the idea) and put it on top of the muffler tip, half of it on lying on top of the muffler, and the other half hanging within the hole of the muffler. Have someone turn the car on, if the dollar gets sucked and went inside the muffler, you have a valve leak... otherwise the valves are ok... I don't know if this is to all cars, but it's pretty popular to many different car owners and seems to work pretty accurately...
    Quote Originally Posted by blink21me View Post
    sir anu po yung leakdown test?
    Sep 2006
    Interesting. I think I'll try that. Thanks.
    Question: How the heck do you get the dollar bill out once it's sucked into the muffler?
    Aug 2006
    sorry for the late reply... I didn't get an e-mail when you posted that question, but take a look at it here
    Aug 2006
    Quote Originally Posted by Dina_DJ View Post
    You don't get it back You just let it burnt
    *blink
    sir salamat sa info...
    my guess is that the valve guides and valve seals of one or more exhaust valves are leaking oil down to the exhaust manifold. kaya meron oil sa exhaust. this could be caused by a bent valve guide bore resulting from the piston hitting the valve when the timing belt broke.
    *yebo
    thanks sir, sir anu po bang pyesa to? ito daw po yun pinalitan eh ska mga belt etc, nahagilap ko lang kanina
    ang pinagtataka ko lang po parang magkakaiba..
    yung malaking diameter ay intake valves ung mas maliit ay exhaust valves
    Sep 2006
    parang pinulut sa lupa.
nababawasan ng langis
