does anyone have any feedback on the Goodyear Ducaro GA tires? they're supposed to be quiet daw...
wala na yata kasi nung Bridgestone Turanza GR-50 SS eh... or if ever, walang available sa size na kelangan ko 185/70/R13
sorry to resurrect this old thread. but the road noise is driving me crazy.
pls tell me if what im doing is right: planning to use flashband on the doors, in case i want to have good sounds later on. maybe only a layer or too. for the floors, acoutifoam.
another question: where do i buy acoustifoam? been too handyman in rob manila pero wala daw. same sa true value shang. or should i specify han gang brand?
thanks all for your inputs.
morrisey, nakabili ka ng flashbands? acoutifoams? san ka nakabili? ako rin, plan ko maglagay.. pero may nabasa ako na dapat hindi asphalt-based un mga ilalagay, kasi daw madali matunaw especially dito sa pinas na super init.. baka bumagsak, specially kung sa ceiling ilagay.. i need to confirm kung asphalt-based ba o hindi ang flashbands..![]()
asphalt based ang FlashBand. even the one i used - FlashingTape - is
asphalt based. pero hindi naman bumagsak or anuman. mas ok pa nga
daw siya kesa sa FlashBand kasi kelangan mo pang i blower or heat
gun yung FlashBand para dumikit. yung FlashingTape ni-roll ko lang using AA size na battery.
btw, kelangan mo lang linis ng mabuti at patuyuin yung didikitan mo.
what i did was clean the driver side door first then tinutukan ko ng
electric fan while i was cleaning the passenger side door. nung tuyo
na i let it stay for a while pa ra mas sigurado akong tuyo na.
(open doors)
naglagay ka rin sa interior ng door? or dun lang sa may door panel? naglagay ka pa ng matting on top of the FlashingTape? or kinabit mo agad un door panel? sa door ka lang naglagay? isip ko nga rin FlashBand (or similar) un ilalagay ko, para mas mura.. pero sa RAAMMat, ang prob daw sa mga asphalt-based, pag tumagal, natutunaw dahil sa init.. tapos mabaho daw.. un RAAMMat ata ngyn, door kit lang 4k na..hehe mahal...
ewan ko sa iba ha, pero yung nabili kong FlashingTape hindi mabaho. baka
sinasabi nila na mabaho para yung product nila ang bilin mo. hehehe...
i only had them sa doors ko. 2 front doors. yung pinto ko may inner at outer shell eh. nilagyan ko pareho. pati yung ibang butas nalagyan ko din. i'll try to
look for the link sa KAC. yung diy ni ... (hindi ko rin matandaan kung sino).
meron siyang pictures.
i plan to put these sa ibang parts sa loob (floor, firewall, ceiling, trunk,
backboard) kapag nag pa paint na ako.
P500++ lang bili ko sa flashingtape.
nakita ko rin un DIY sa KAC, actually, galing un sa site ng RAAMMat... same procedure, iba lang un material na ginamit.. meron din sa pbase - http://www.pbase.com/gino/sound_deadening gamit naman nya flash band.. dun sa KAC/RAAMMat, xempre gamit nila RAAMMat..hehe pero nun check ko, halos same un ginawa..so ok for you pala un FlashingTape..meron kaya sa Ace hardware nyan? sabihin ko lang ba FlashingTape? Also, ano un pinanlinis mo sa doors bago kabit un flashing tape?
the road itself does not make noise. it is your tires on contact with the road and your suspension insulators that transmits vibration and noise inside the cab. start with cruising tires. even a lexus sedan will make noise if you use the wrong tire. then, check your suspension rubber bushing for wear and age. if they are not firm and pliable anymore, it might be time to replace them. long before rubber insulators (bushings) were installed on the suspension, they used metal to metal, that's right, metal to metal flex joints on the lower control arms. they transmit noise and worse if not lubricated with suspension grease an additional squeakiness (specially ford) happens. in the late '70's, the suspension were insulated and even the engine noise isolation was beefed up by the additional rubber insulation on the engine/transaxle cradle to further isolate noise, vibration and harshness (NVH). with your car, again start with the right type of tire with the correct air inflation pressure. nip the problem at its cause or origin similar to spraying air freshener in the room without removing the dead rat, would still smell dead rat
