mga sir, im planning to change my tires this weekend, and gusto ko lang kumingi ng opinion, sino ba mas ok goodyear or yokohama? performance, quality, etc.... and i asked the supplier na local lang pala sila pareho. ano po advice nyo? thanks![]()
kahit alin bro basta properly aligned ang camber mo at balanced ang tires. try mo rin falken kasi from my experience ganda ng performance at kahit di ko napa-align yung sasakyan ko, even ang thread wear ;)
Depende sa model ng tire. Parehong brand ay may mga high-end at low-end na models. Sa mga nabasa ko, mas ok ang Yoko kung local vs local na budget tire (e.g. S306 vs NCT's).
Pero ako, mas tiwala ako sa Japan-made na Yokohama. May ibang shops hindi nagbebenta ng Japan-made puro local lang. Oks ang experience ko sa Japan-made Yokos sa Corona (A539 dati, C.drive ngayon).
Natry ko din local Yokohama S306 (RP-made) sa Lite Ace, naflat na once (pako), pero otherwise ok.
ayaw mo bridgestone? tingin ko mas sturdier sya.
pero i'm using yokos now.
kung Goodyear balak mo, the Ducaro tires are excellent, quiet and cheap. nakarami na kme nyan sa revo namin, sulit masyado tibay pa.
curious lang...wala bang kumho tires dyan? one of the better values sa tires dito.
if you are choosing goodyear, avoid buying the NCT3 model tires. Although they are cheap, they loose their grip easily in the rain. NCT3 tires also do not gradually loose grip, they grip now and do not have grip in the next second.
Don't base it by brand alone, NCT3 by Goodyear is the crappiest of crap you can buy, but NCT5 is much better... So walang sense comparing brands alone... Especially true if you're referring to low-end passenger tires like 14s and 15s. Get the ones with long tirewear and check the year it was manufactured... Tires usually start to stiffen after 3 years, so if you get a new one manufactured 2-3 years ago, it'll get damaged very easily.
Sidenote: Mura benta ni Baiskee sa gulong nila.
onga pala, ok ang dunlop, mura na tibay pa especially the 17" and above sizes
michellin gamit ko. tagal mag wear out. smooth...happy ako...6 yrs warranty pa. kaya lang MAHAL...at 1850 each...sale na sya sa lagay nyan yun
ok. maraming salamat po sa info nyo nga sir, to sir jim check ko sa supplier kung magkano falken baka mas mura. hehehehe! nag-inquire ako yokohoma puro locl na daw nilalabas nila, ang japan made lang is 15inch up. to sir ghosthunter oo nga yun isa sa tire ko NCT3 madaling maupod. mukhang d ok yun.
Originally Posted by theveed
ah ok. so that is what baiskee was pertaining too when he texted me once to inform me that he was selling rubbers.... i thought he was selling condoms...![]()
sir,Originally Posted by IIE
as goodyear always say. "it is made matching the philippine condition..."
sabi nung nag seminar ako sa goodyear
