Results 1 to 6 of 6
- Feb 2005
- 37
September 20th, 2005 04:33 PM #1ano po bang naghohold dito? is it easy to diy or kelangan na ng especialista?
i need to hold the lever while turning or switching lane kse ayaw nga nya kumagat....TIA!
- Feb 2005
- 37
September 21st, 2005 11:33 AM #4
yup. baka hindi exact fit yung adapter.
i assume generic boss kit yan.
ganyan kasi yung sa akin before. so to fix the problem, i reverted back to my stock steering wheel.
September 22nd, 2005 04:02 PM #5
baka putol na yung parang clip nya, nangyari na yan sa oto ko, pinalitan ko yung combination switch, buo pala yun pag pinalitan. And tanung ko na din mga sir, di ba pag nagpalit ka ng steering wheel yung adapter salpak lang at meron ba itong koneksyon sa combination switch?
September 22nd, 2005 05:35 PM #6
there is a pin inside the steering wheel that when you lift the level to turning right, after the steering wheel move back to its orignal position the said pin will trigger the turn signal mechanisn to off . either the pin is broken which can be repair, however if you change steering wheel it was not palce in the right positioning. In that case, have a mechanic to check.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
