Originally Posted by
vinj
What's the mileage of your Nissan Escapade? The release bearing could be due for replacement if you hear a sound (grinding or ringing sound usually) when the clutch is not pressed down. Usually when the clutch assembly has to be brought down to change one of the parts (release bearing, clutch disk and pressure plate) the recommendation is to change everything already as the labor just covers one item for all three parts and if your car is already high mileage and the clutch is worn then perhaps you can change it all already. But if your car is still low mileage and/or you've racked mostly highway mileage (where your clutch isnt that stressed out) then you can just change the bearing.
The casa will charge high for labor and stuff. You may want to canvass around at other shops then just use original parts (from the CASA or a Nissan auto supply).
